Wheel nut tension
Submitted: Monday, Apr 05, 2004 at 20:45
Stuart
Hi gang, I was just wondering if anyone knows the correct tension for wheel nuts on a Landcruiser. I am not being anally retentive but just about every bolt on the car has a specified tension but I can't find a value for the wheel nuts in either the original or after market manuals. I have found through experience that if they are to loose the
wheels fall off and if they are to tight the studs snap. Thanks. PS. "snap it and back half a turn" does'nt count.
Reply By: Martyn (WA) - Monday, Apr 05, 2004 at 21:07
Stuart,
118 to 147 Nm is usually the range I do
mine to 135 Nm. If you have alloys they will be slightly different and would need checking more often, I don't have a number sorry
53303
Reply By: Wayne (NSW) - Monday, Apr 05, 2004 at 21:37
Stuart,
Using a rattle gun will over tighten the studs. The wheel brace that comes with the vehicle, which is a single bar with a socket on the end, will also tend to snap the wheel stud because of all the pressue being applied to one side of
the nut. I have found the X brace to be the best. Four diffrent sockets to chose from and a even amount of leverage applied to the stud. Using this brace the studs can be tighten and lossen very easily.
If using one of the X braces, paint the socket that fits the wheel nuts on your vehicle, saves trying all four to find the one that fits.
Wayne
53310
Follow Up By: Wayne (NSW) - Monday, Apr 05, 2004 at 21:48
Stuart,
Because I don't take a tension wrench with me I tighten the wheel studs until my back cracks and then back off a little.
Wayne
315021
Follow Up By: Stuart - Monday, Apr 05, 2004 at 21:58
Thanks Wayne, and every one else. I never use my rattle gun to tighten wheel nuts but I do use the star bar if I'm caught out away from home with a flat. I have tape wrapped around the correct size end to protect the center caps from scratching. (I hade them chromed). The tension wrench is used in the garage while doing pre-flight maintanance.
315023
Reply By: Phil G - Monday, Apr 05, 2004 at 21:43
Prado 6 stud are 113Nm. Lubricate the threads and mating surface with a smear of grease (or antisieze) and reduce the chance of broken studs.
53311
Reply By: Jayson - Tuesday, Apr 06, 2004 at 07:15
Stuart,
I used to be a surveyor here in
Karratha and have driven all sorts of 4wds with my own car a td 100. I have always had the smallest, lightest person who might drive the vehicle do a stud up and undo it so I could gauge the right torque. I do this so that that person can get the wheel off if it all comes unstuck. I'm 6'7" and if I did them up tight for me no other bugger could get them off and worst case the wife would be stuck on the side of the road cursing my name and asking for help, even though she is more than capable of changing a 4by tyre. I've had a few studs break on the 6 stud troopy and 75 utes, never had a tyre and rim leave the vehicle and never broken a stud on the 5 stud 'cruisers. I just use the standard 4 socket wheel brace.
Hope this helps
Jayson
53340
Reply By: Paul's lot - Tuesday, Apr 06, 2004 at 08:29
Please dont take this the wrong way but if you cant judge how tight to do your wheel nuts I suggest you let someone else change your tyres and do your mechanical work. Tight is tight. The average bloke wont overtighten with a cross brace with the length of the bar invoved so long as you never slip a pipe over a brace to tighten nuts you should be right.
53347
Follow Up By: Stuart - Tuesday, Apr 06, 2004 at 11:23
Thanks Paul, I've been working on cars all my life and have seen a lot of mistakes made by people. I have never snapped a stud or had a wheel fall off but I have seen others who have (and had to fix them). I managed to convert my 80series 3F to a 350 vortec Chev on my own so I think I know what I'm doing. I merely brought up the question out of curiosity because none of the service books I had mentioned it. Maybe I'm just cautious but in all my years of travelling I have had VERY few brake downs. No offence taken. Cheers.
315068
Reply By: Topcat (WA) - Tuesday, Apr 06, 2004 at 08:59
The correct tension for wheel nuts as specified by Toyota is 137Nm (101 ft.lb). Cheers.
53350
Reply By: phil - Tuesday, Apr 06, 2004 at 11:30
Good tyre
places in NSW use only a cross brace to tighten the nuts. Rattle gun just to take up the slack. I think there may even be a regulation to this effect.
As someone else mentioned it is important to lubricate the thread and mating surface otherwise the real torque could be almost anything. Just do them up with the cross brace to whatever you can easily apply without excessive force. Remember you have to undo them again some time. Never "back off" again since this will leave little tension on such a short stud.
53368
Reply By: Member - Jeff M (WA) - Tuesday, Apr 06, 2004 at 11:53
It is a very valid question IMHO as I had 3 studs sheer off on a 5 stud wheel and lost a wheel at 100km/h. Not a very nice feeling. The wheel was done up by hand (I watched him do it as his rattle gun would'nt fit on the alloy rims) at the trye place down the road from my house. It took 2 weeks (complete with fully loaded
camping trip and 4wding) before they came off driving to work unladen on the highway. You can't be too careful. Certainly opened my eyes up to exactly what is holding all that weight we pile into our vehicles and all the pressure we put them under on corrugations and corning etc. When you think about it, it's those little metal rods that slip through the holes in our rims that are keeping everything together... Kinda scarey hey!
We spend so much money on tryes, shocks, springs, stabalizers blah blah blah, but what about our studs? Arrgh who cares, she'll be right....
53373
Reply By: duncs - Tuesday, Apr 06, 2004 at 15:31
Hi All
Having had a pre trip check done by a
well respected 4wd service agent in
Sydney I had heaps of trouble with wheel nuts on my subsequent trip.
In
Cairns I had a tyre
shop remove a wheel that I had benn unable to get off in the bush. He put a three foot bar on the wheel nut and jumped on it, repeatedly to loosen
the nut. I now always use the torque wrench to do up wheel nuts, yes I carry it everywhere. The thing that suprised me most was how little tension is required. The speck in the genuiine Nissan manual for a GQ is 80ft/lbs.
Stuart, others have told you the speck for your vehicle I'd do the wheel nuts up to that. If your not sure ask the service dept at the local Toyota dealership. Thanks for raising what is a little thought about but very important issue. And don't worry about those who want to critisize.
Duncs
53412
Reply By: Member - Paul- Tuesday, Apr 06, 2004 at 16:47
Use cross wheel brace and tighten each nut until you see blue lights. Wheel guaranteed not to come off.
Paul
53428
