<span class="highlight">Wiring</span> ARB CKMTA12 air compressor
Submitted: Sunday, Jul 12, 2015 at 10:38
BrigalowO
I have fitted my compressor into a designated space in my storage drawer system, and I am wanting some advice on the
wiring.
This unit is an on board type with the
wiring harness/s, including air lockers which I don't need, as I only want it for inflating/deflating tyres.
I am a bit confused as the diagram shows three switches, 1 - for air locker- 2 for air locker and 3 for an isolating switch. What I want to know is which switch do I use?
Robert
Reply By: Member BarryG - Sunday, Jul 12, 2015 at 11:02
Hi Robert,
My Landcruiser has an on-board compressor, with air lockers, wired up by ARB.
The way
mine is installed is with the three switches you mention. The reason for the isolation switch is so that the air lockers cannot be inadvertently activated. They will ONLY operate if the isolation switch is turned on.
In your case, just install the isolation switch, it is that one which provides power to the compressor.
Hope this helps.
Barry
556915
Reply By: Allan B (Member, SunCoast) - Sunday, Jul 12, 2015 at 17:00
Hi Robert,
The standard ARB 3-switch setup is the "Compressor" (isolator) switch controls 12v power to the compressor.... it turns it on & off. The other two "Airlocker" switches are for the solenoids that provide air from the compressor to either the front or rear diff lockers. If you are only using the compressor without lockers then only install the "Compressor" (isolator) switch and insulate any unused bare connections.
556935
Follow Up By: BrigalowO - Monday, Jul 13, 2015 at 10:25
Thank you Alan and Barry. I am very grateful for your help.
It all makes sense now , but when you get to 75, I think we tend to lose a bit of that. LOL
Robert
843237
Follow Up By: Allan B (Member, SunCoast) - Monday, Jul 13, 2015 at 14:50
Not a bit of it Robert...... "Older and Wiser" mate, Older and Wiser! LOL
843260
Reply By: Member - graeme W (WA) - Monday, Jul 13, 2015 at 21:22
Hi Brigalowo. One thing to keep in mind when
wiring the compressor. I presume the drawers are in the back of your tug which is a fair way from the starting battery. I think
mine draws about 35amps so you may have increase the cable size.
Cheers Graeme
556991
