Holland's Track
Submitted: Tuesday, Apr 13, 2004 at 20:56
brownie
We drove Holland's Track from
Broomehill to
Coolgardie over the
Easter weekend.
The trek notes from this site were a fairly accurate guide to the trip.
Well done to the writer.
Brownie.
Reply By: Davoe - Wednesday, Apr 14, 2004 at 13:16
good to hear I am planning on doing the ht sometime but have a higher and wider than standard vehicle - were there any tight or low spots? ta in advance
54170
Follow Up By: brownie - Wednesday, Apr 14, 2004 at 21:37
Good Luck !! Long distances of the track are just 6' wide. We travelled with both mirrors folded in for most of the trip. Height probably not such a problem if you are careful.
What are you driving ? I will give you my opinion as to whether to tackle the track or not. I drive a Landcruiser trayback with a canopy, it is exactly 6' wide.
Cheers, Brownie
315918
Follow Up By: Davoe - Thursday, Apr 15, 2004 at 09:52
It is a l/c camper but not a troopie It sticks out from the cab about the same distance as a normal tray but being a camper is far les robust and is 2.7m high. I am seriosly thinking about getting a normal trayback with a canopy coz I just cant get to all the
places i want TA
315976
Follow Up By: brownie - Thursday, Apr 15, 2004 at 23:24
If your camper is not much more than 6' wide then that won't be a problem. The height will require you to take more care - there are a few lurking branches ! Be prepared for the camper body to take a bit of punishment from the scrub on the sides of the track. The scrub is very thick and goes for quite long distances.
If you were to take it very steady, then you would probably be ok. We travelled at between 20/30 kph, you would need to go slower.
Cheers , Brownie
316132
