100 SERIES BODY LIFT
Submitted: Monday, Apr 19, 2004 at 20:45
Tim
I am about to do a body lift of about 20mm on my diesel, rigid axle Landcruiser 100. I would appreciate thoughts, tips or tricks from anyone who has done this. In particular modification (if needed) of the fan shroud and radiator.
Thanks,
Tim.
Reply By: Member Eric - Monday, Apr 19, 2004 at 22:01
20 mm isnt 2 hard . If you have a airbag vehicle , I would sugest you dont do it . It affects the sensors I have been told . If its a non airbag vehicle . its not to hard . Since you are only doing a 20 mm lift , look at spacing up your engine mounts instead of droping radiator .
55045
Reply By: bernie1 - Tuesday, Apr 20, 2004 at 08:27
Tim,
I have 2000 mod std diesel with live axles. I fitted heavy duty coil springs with a 25mm lift front and back 12 months ago. I did no other mods. Has not affected anything. Hope this helps.
55093
