mud terrain tyre pressures in Patrol gu
Submitted: Tuesday, Apr 20, 2004 at 22:06
tim
Hi All
Does anyone run mud terrains in there gu patrol wagon and what pressure are you running at, so i can get maximum wear out of them?
I just changed those bridgestone duellers you get standard on the patrols and bought a decent set of tyres.
I usually run with no weight in the back(wagon) unless heading away but have bar,winch,dual batts in front.
Tim
Reply By: Truckster (Vic) - Tuesday, Apr 20, 2004 at 22:45
What brand and size MT's are you running?
55229
Follow Up By: tim - Wednesday, Apr 21, 2004 at 07:19
Hi Truckster
285/75/16, BFGoodrich
317014
Reply By: Leroy - Wednesday, Apr 21, 2004 at 08:21
Hi Tim,
I have BFG MT's also and run 36 around the streets and 24 on the dirt. You can run a bit more on the bitumen depending if you have a load etc or don't mind a harsher ride. Bro in law also has the same setup and runs 38 on the bitumen and 24 on the dirt and tyres are wearing evenly.
Leroy
55257
Follow Up By: macandjen - Wednesday, Apr 21, 2004 at 20:28
Leroy, how many K's have you got out of your muddies? I am thinking of doing the same as Tim but unsure about wear rates. I would be running the same size as him. Any advice appreciated.
317191
Follow Up By: Leroy - Friday, Apr 23, 2004 at 19:40
They 're new!. But bro in law has 22k and they look to be about 50% worn but they have done a lot of hard off road work.
Leroy
317546
