patrol zd30
Submitted: Tuesday, Apr 27, 2004 at 23:06
ThreadID: 12440 Views:7902 Replies:3 FollowUps:3
Just hoping that some one might have a list of the fault codes for the nissan patrol gu with zd30. I now know how to access the codes but I need to know what faults they list.
Thanks in advanced
Bob A
Reply By: Leroy - Tuesday, Apr 27, 2004 at 23:50
have a look down the page. someone posted for a navara (same engine)
Leroy
AnswerID: 56321
Follow Up By: bob - Wednesday, Apr 28, 2004 at 08:42
leroy
that posts tells you how to access the codes. I need to know what the codes are
thanks
Bob A
FollowupID: 318070
Follow Up By: Leroy - Wednesday, Apr 28, 2004 at 10:32
Ah sorry I shoulda read a little closer!! Someone here has the gregory's manwell so maybe they may post them?
Leroy
FollowupID: 318081
Reply By: fourstall2000 - Wednesday, Apr 28, 2004 at 11:46
Gregorys put out a manual for your engine,contains all fault codes and how to test all electrical equipment. At about $60 the best money you will spend.
AnswerID: 56372
Reply By: crowie - Wednesday, Apr 28, 2004 at 20:31
hope this helps
ZD30 Self Diagnosis Fault codes
The fault codes indicate a malfunction in a particular circuit and do not necessarily mean that the component itself is faulty. Check the entire circuit, eg: connectors wiring as well as the component. Intermittent faults may indicate loose, dirty connections or a bad earth.
0102 – air flow sensor
0103 – coolant temperature sensor
0104 – vehicle speed sensor
0203 – throttle pedal switch
0208 – cooling fan control
0301 – engine ECU
0402 – fuel temperature sensor
0403 – throttle pedal position sensor
0406* - intake air volume –VNC system
0407 – crankshaft position sensor
0502* – battery voltage
0504* - auto transmission communications line
0701 – injection pump – cam ring position sensor
0702 – " " – TDC pulse signal
0703 - “ “ - communications line
0704 - “ “ - spill valve
0705- “ “ - ECU
0706 - “ “- spill valve
0707 - “ “- injection timing control
0802 - Engine ECU
0804* - Engine ECU
0807 - stop lamp switch
0901 – Engine ECU
0902 – Engine ECU relay
0903* - Engine ECU
0905 – Intake air pressure sensor
1003 – EGR volume control valve
1004 – Injection pump – fuel cut out system.
Codes with (*) symbol do not illuminate the check engine warning light.
Regards Crowie
AnswerID: 56456
Follow Up By: bob - Wednesday, Apr 28, 2004 at 23:40
crowie
thanks for your help. just what I was looking for
b
Bob A
FollowupID: 318239
