AnswerID: 4096 Submitted: Sunday, Jun 09, 2002 at 00:00
replied:
Rob I too have a Garmin, well two actually an old GPS75 single channel/multiplexed unit and a GPS12XL.
The 75 will work ok outside but in the car definitely needs the external antenna while the 12XL works ok but for steep heavily treed country an external antenna is better.
You may find that your
gps will work ok up on top of the dash but loses signal when heading south (as the satellites are in an equatorial orbit) and an external antenna is required to overcome it.
If your
gps cannot accept an external antenna then as you say a re-radiating antenna/trannsmitter is the only solution apart from upgrading your
gps to a different model.
The best place to ask the question would be at www.gpsoz.com.au as Brian is very familiar with what is available.
Reply 3 of 4
FollowupID: 1774 Submitted:
Tuesday, Jun 11, 2002 at 00:00
Peter posted:
I was actually trying to explain what the orbit was, it isn't actually an equatorial but they all rotate more around the centre of the earth more than the top and bottom. Does that make it any clearer?
If you have alook at the Garmin site it explains it better.
FollowUp 2 of 3
