80 series aux tank transfer problem
Submitted: Sunday, May 09, 2004 at 17:20
locallaw
Gidday, can anyone tell me how long to transfer fuel from the aux to the main
tank.
The last time it the better part of an hour.Could the line between the 2 tanks be blocked slightly????.
Thanks Locallaw
Reply By: bmbiker - Sunday, May 09, 2004 at 18:12
It should not take that long. Never timed
mine but at that speed you would nearly run out of fuel. May be 10 to 15 minutes at most.
57866
Reply By: Steve - Sunday, May 09, 2004 at 20:35
How do you transfer fuel from one
tank to another ? We are talking an 80 series with twin tanks as standard ? I run out the fuel from the sub
tank then switch to main
tank..switch is standard and on the dash..
57894
Follow Up By: Kev - (Cairns,QLD) - Sunday, May 09, 2004 at 21:22
I think the diesel & petrol set ups are different, diesels have 2 seperate tanks & lines where the petrol 80 series dumps one to the other........as i said........i think !
Or it could be aftermarket.
319651
Follow Up By: Moose - Monday, May 10, 2004 at 13:51
Kev's right - in the petrol the fuel transfers from the aux to the main.
319729
Reply By: Moose - Monday, May 10, 2004 at 13:56
Sorry can't answer your question directly as I now have a large aux
tank and I can't remember how long it used to take. But if you look in the "manual" that came with the vehicle I'm sure it tells you how many litres per minute it transfers so you can work it out for yourself. It certainly shouldn't take an hour. Also don't forget that it will only transfer until the main is 3/4 full (approx) and then stops.
57974
Reply By: locallaw - Wednesday, May 12, 2004 at 19:08
Gidday All,thanks for your replys I didnt read the instructions.Now I know how everything works.
Seeya Locallaw
58361
