Hyundai Terracan Snorkel
Submitted: Monday, May 17, 2004 at 21:15
Ballbelter
I'm taking a trip up the Cape in July and need to fit a
snorkel to the car due to the extended wet season they have been having. I have come across a problem in that I can't seem to find anybody in
Brisbane that supplies snorkels for this model.
Can anybody point me in the right direction?
Reply By: Wayne (NSW) - Monday, May 17, 2004 at 21:37
It is a matter of supply and demand. Not enough call for a
snorkel for the Terracan.
If you think that you will need one, try a muffler/ exhaust
shop and they should be able to bend one up.
Wayne
58994
Reply By: Davoe - Tuesday, May 18, 2004 at 14:03
terracans are petrols with full electrics right? I think if you are attempting
water crossings at such a hight you need a snorkal then you would be risking alot as this would be
well above the manafactures recomendad wading depth which I would imagine is around 500mm or less a petrol will often stop (without proper precautions)
well before it reaches ingestion depth i have seen a petrol cruiser stopped in 700mm
water also other things to consider (if you havent already) is the diffs and gearboxes do they even have breather hoses. I might be off the mark with this post and you might own a modified hyundai and just after a snorkal to top it off but on the other hand if you havent owned a fourby before and believe the adds that all you need to drive underwater is a snorkal you may find your photo on the last page of a 4by mag
59074
Reply By: don - Tuesday, May 18, 2004 at 22:09
G.day ballbelter,
I have a Santa Fe and extensive research tells me that If it aint a toyota/nissan or??? no one is really interested, HOWEVER about to get me a stainless steel custom bend made up, as you know it aint the depth its the driver but having an airintake 6 inches off the gravel does make it difficult.
Don the duck.
59181
