Hj 60 power steering
Submitted: Tuesday, May 18, 2004 at 17:45
ThreadID: 12981 Views:1774 Replies:3 FollowUps:0
Hello all my sons hj 60's power stering pump is leaking heaps of fluidi believe there is a seal kit available,does any one know if this is a job you can do at home or does it need a specialist mechanic. any assistance appreciated thankyou.
Reply By: Eric from Cape York Connections - Tuesday, May 18, 2004 at 18:05
Brian my pump leaked and got a kit suplied and fitted it cost about $ 300 that was about 2years ago.
Good luck
Eric
AnswerID: 59123
Reply By: ToyMotor - Tuesday, May 18, 2004 at 20:03
Hi Brian,
Genuine seal cost me about fifteen bucks, the shaft might be a bit stuffed and need some work, I was also quoted $300 to supply and fit the seal. It's not difficult, check the manual.
AnswerID: 59144
Reply By: Kiwi Ray - Wednesday, May 19, 2004 at 08:49
Hi Brian
The kit is only a few "O" rings and a seal.
If you have access to a hydraulics repair shop you will be able to buy the parts from them.
cleanliness and care when stripping and assemble, hydraulics do not like dirt
Parts to ovefhaul 80# pumps cost me $30
Hope this helps
Ray
AnswerID: 59216
