gq patrol passenger side headlight
Submitted: Friday, May 21, 2004 at 13:46
KO2004
Hi there,
We keep blowing this headlight (either that or it turns itself on and off...) and have heard from one place that this is common.... It might be common but does anyone know how to fix it?? Gremlins
Karen
Reply By: Kiwi Ray - Friday, May 21, 2004 at 13:52
Hi Karen
Check all the earth points, remove, clean, and refit
Also check the earths for each individual light unit
Ray
59566
Reply By: flappan - Friday, May 21, 2004 at 13:52
Sounds like a bad connection and or a short somewhere.
Not common AFAIK.
59567
Reply By: KO2004 - Friday, May 21, 2004 at 13:58
Thanks for that. Will look tonight. Just had the bloody thing serviced (at a cost of 6k) and the last thing we expected was the alternator to blow up and then this... growl
Karen
59571
Follow Up By: SupaMav - Saturday, May 22, 2004 at 00:12
Holy cow! $6k is a bloody expensive service. What was done?
321269
Reply By: Flash - Saturday, May 22, 2004 at 17:44
Yeh,
I keep blowing that head light too, about every three to five years or so....
Seriously, if it's a halogen H4 bulb and blows then maybe you need to check your alternator output voltage.... or maybe you've touched the globe with your fingers. That is a no-no. Also do NOT get cheap bulbs- most are garbage.
59702
Reply By: KO2004 - Monday, May 24, 2004 at 09:16
Yes 6K is what I said.
We had the following done
OME
suspension
removal of gas system and replaced with long
ranger fuel
tanksnorkel
disk rotors
all axle seals
2nd battery (the system was already in)
2nd outlet for fridge in rear of car
major service (all oils changed)
Yay we thought we were on the road and ready for
Cape York but guess what? the light blew again and THEN the alternator... the bloody thing didn't even make it out of the garage... does anyone know a decent mechanic for fourbys in
Canberra area?
59859
Follow Up By: Bonz (Vic) - Monday, May 24, 2004 at 13:57
thats a bit more than a service, hope you get it sirted and have a great time at
the tip of Oz
321503
