GU Patrol Front Diff Breather
Submitted: Saturday, May 22, 2004 at 12:44
ThreadID: 13071 Views:2054 Replies:3 FollowUps:2
Hi All,
How do I check if the front diff breather of my series III, 3.0TD GU patrol is clear?
I follow the breather hose from the diff to the firewall and up and then it disappears into the L/H guard with 2 other pipes. Do I pull off the hose at the diff, or is there another way?
Rob
Reply By: Truckster (Vic) - Saturday, May 22, 2004 at 19:12
Remove the inner guard and follow it from there up to where ever it goes..
AnswerID: 59713
Follow Up By: Member - Errol (York WA) - Saturday, May 22, 2004 at 20:41
Good answer Truckster . lol he he he
FollowupID: 321322
Reply By: Member - AndrewPatrol - Monday, May 24, 2004 at 18:39
When i fitted the snorkel , found that the pipes you describe finished buried in a block of sponge that is removed when the snorkel is fitted. The pipes now finish in thin air! One day i'll get around to fitting a hose on 'em. You access them as truckster describes- take note how the plastic things comes off. Maybe you could attach a hose at this end and take off hose from diff and blow???
AnswerID: 59941
Follow Up By: Rob W. - Tuesday, May 25, 2004 at 09:13
Will have another good look on the weekend and see what can be done.
Removing inner guard sounds like a lot of work just to check a breather.
Rob
FollowupID: 321628
Reply By: Member - AndrewPatrol - Monday, May 24, 2004 at 18:41
AnswerID: 59942
