FollowupID: 1867 Submitted:
Friday, Jun 21, 2002 at 00:00
Den posted:
G'day
Ross...
The original filters get a change on the 20,000km -30,000km change, since the dunny rolls are taking care of the stuff down to 2-3 microns, the other filters are just about obsolete, but they still get changed when recomended by the blokes who make the good oil...My own thoughts are, that the original filter takes care of the big chunks of garbage and the other takes care of the rest...A very old and experienced mechanic once told me " The life of your engine IS the quality of you oil" I have always remembered this and have never had an engine failure due to oil problems...(Only water problems, ((not the lack of it either, too dammed much down the air intake)))...
One thing i did not mention earlier, you may see quite a noticeable DROP in oil pressure when the dunny rolls get a bit clogged, no bother really, just change the filters and get back
on the road, some people seem to think that the drop in pressure is a failing, on the contrary, i see it as a plus, (you know when the oil is getting dirty with soot and other garbage)...Good luck Den
