Wednesday, Nov 18, 2015 at 19:54
I am no expert but have a look on the us rv sites and you tube. I am confident it will work because I am sure I read reviews or you tube videos of guys having it done.
The heron is a proper rv
generator and from memory I think in the US they sell a specific hard start kit for it or you can use one of these kits.
Ok basically there are 2 or 3 wire kits. The 2 wire kit seems good. Just
check if your heron has a start capacitor or not.
The wiring is super easy. 2 wires. Just depends if your unit has a start cap or not as to were you plug it in.
If unsure a sparky would do pretty cheap.
From what I learnt is that all gennys must be able to run in overload for several seconds to meet AS.My genny is an inverter type sold at BCF like the Honda and they hate overloads.Compare the specs they should be similar.
The hard start kit starts the compressor within .25 of a sec or thereabouts.
Once the compressor starts turning amps drop dramatically it automatically turns the start windings off.
So it firstly gives it a quick boost to start the aircon, lowers drawn start amps and fools the genny if in instantaneous overload so it keeps going.
My genny just revs up for 1 second and then revs down and keeps going. Doesn't even max out at any time.
I got suspicious as I have a portable aircon I use in my sons cabin and it started with the genny without strain. I opened it up and it has a huge start cap and some other circuitry so nothing dims.ie voltage regulators
It figures since you will plug it into a powerpoint near other appliances.
I make no money out of all this info, I just wanna help fellow travelers from what I learnt cause the rv industry here are
sharks.
Also wont have to park near vans with huge gennys lol.
For $11.00 plus postage it is worth a try.
861030
