camper trailer struts. Help please
Submitted: Friday, Dec 11, 2015 at 17:12
Member - lyndon NT
Hi All
Have a mate who has a CT with a boat on top of it. Works
well. He has now bought a fold up trailer which he would like to be able to leave intact strapped to the top of the boat. The trailer is alloy and hence quite light.
However this will mean the existing struts won't be able to lift the load. Has anyone had a similar situation and if so how did you resolve it? Realising that once the lift scenario is sorted we would have created another issue of getting it back down. Think that might be more easily solved but am interested in idea's on that front also.
Lyndon
camper trailer
camper trailer
Reply By: Bob Y. - Qld - Friday, Dec 11, 2015 at 19:32
Have a look
here Lyndon. There is a formula on one page, to work out what you need. If the trailer is very light then I doubt you'll need to upgrade by much. From what I've found with struts is they often need a little assistance to lift the item, but as long as they keep it in place then everything is cool.
Ovesco also sell a variety of struts, and their service is excellent.
593704
Follow Up By: Member - lyndon NT - Saturday, Dec 12, 2015 at 16:44
An extra 50 kg is going on the roof. I have found the part number on them and the manufacturer is still in business so should be able to get info out of them.
862035
Reply By: PhilD - Friday, Dec 11, 2015 at 23:34
You can get gas added to good quality struts, by
places like Strut Regas. I had a 4.1 m composite boat on my Kimberly Kamper, and used a small winch with dyneema rope on a sleeve on the side of the loader to winch it over to the point of equilibrium, and then used my weight to finish closing it. I used the winch to let the loader slowly release so I always had control of it.
593714
Follow Up By: Member - lyndon NT - Saturday, Dec 12, 2015 at 16:45
I would think that type would have to have an external valve? Yes?
Not so with these.
862036
Follow Up By: PhilD - Saturday, Dec 12, 2015 at 18:07
No, the standard struts can have gas added to them. There is no external valve.
862040
Reply By: Injected - Saturday, Dec 12, 2015 at 02:58
Struts Australia is another supplier of Gas struts. I have purchased about 7 over my time from them.
Just a tip: 100kn force strut is about 10Kgs of force.
593716
Follow Up By: Member - Rosco from way back - Saturday, Dec 12, 2015 at 12:03
Oops ............. 100 KN is about 10 tonnes force (adopting a value of 10 for G)
100 N (newton) is about 10 Kg force.
862027
Follow Up By: Member - lyndon NT - Saturday, Dec 12, 2015 at 16:47
LOL, yes, I knew when I saw the k that there was a slight error :-)
862037
Reply By: Rangiephil - Saturday, Dec 12, 2015 at 13:25
You can get struts in different strengths or newtons.
They come in various strengths from say 200 newtons up to 1100 newtons.
See if you can see the newtons on the strut and if not contact the camper trailer manufacturer.
You can then select one with higher newtons ,and fit them.
Just be aware that you need a considerable tool to compress struts if they are not fully extended, and all thread alone does not qualify as it bends.
Regards Philip A
593724
Follow Up By: Member - lyndon NT - Saturday, Dec 12, 2015 at 16:42
Cheers, Think we just need to work out which one's we need and will get someone else to fit.
862034
Reply By: Member - lyndon NT - Saturday, Dec 12, 2015 at 17:54
I am trying to talk my mate into forgetting
trailer
about the strut thing and "upgrading" to a rig like this......................
593735
Follow Up By: ian.g - Monday, Dec 14, 2015 at 11:48
The
fork lift to get the boat down must be on the "A" trailer
862110
