Led light Bar <span class="highlight">wiring</span>
Submitted: Monday, Aug 29, 2016 at 11:30
warren h1
Hi just trying to wire up Led light bar and would like a few pointer in marrying the led diagram up with the switch diagram.Have attached the two.cheers Warren
Switch Dia
Led Dia
Reply By: chaz r - Monday, Aug 29, 2016 at 13:15
Wiring diagram
I thought this one would be more descriptive. Cannot understand the original diagram come with the
wiring cables, I contacted the seller vicoffroad, and they provide this
wiring kit instead.
Based on my understanding, you need to connect the light to your high beam. Please note there are two types of wires. I got another
wiring kit on my tractor that goes direct from light to the battery, I could switch the light on anytime. But this cable is a bit complex as I was told, you needa make sure the light is controlled by an independent switch through the high beam. So there is no way you could make the light as your high beam long shooting force....
Hope this
pic is helpful to you
603939
