Remove 2004 LC100 driverside cargo area side trim
Submitted: Sunday, Sep 25, 2016 at 10:49
Trevor
Can somebody tell me how to remove this trim? I need to run a TPMS cable to the external rear of the vehicle. There is already an accessory cable fitted and running out of an OME rubber boot in the underside of the wheel arch, I just need to get to the boot.
I have tried pushing a snake back up the panel from the boot but that does not work.
I have a draw system installed which will cause me some aggravation in accessing the panel.
With Thanks
Trevor
Reply By: TomH - Sunday, Sep 25, 2016 at 11:03
From what i remember it just all pops off Start by pulling door seal off in required place and work it off It has plastic plugs that just pop out. will also have to pull carpet back as it tucks under it best to take panel across rear floor off first about 8 screws in it Dont have to take trim around window off.
You may be able to pop it along under window and just drop a cable in behind it and get it down to the grommet. I did it for a reversing camera which I fitted in the top taildoor
Buy a few of the plugs as they have a habit of breaking or deforming and dont hold on replacing Not expensive at a Toyota dealer.
Will be interesting with drawers Best to try just popping the top and pulling it out an inch or two
604632
Follow Up By: Trevor - Sunday, Sep 25, 2016 at 11:13
Thanks for the info Tom - Its not possible to remove the panel across the floor The rear support for the draws run across that panel. (I guess you mean the panel that hinges the trim across
the gap when the lower tail
gate is down) As you say - it will be an "interesting" job
T.
874416
Reply By: Mikee5 - Sunday, Sep 25, 2016 at 12:44
What Tom said is correct. The side trim is held in place at the bottom by the floor mat. To completely remove the side trim, the drawers and floor mat must come out. It is possible to remove the side trim from the top only and do the wiring that way if you have long skinny arms. To do this pull away from the top and work around the edges. You are sure to bust some clips.
604635
Reply By: TomH - Sunday, Sep 25, 2016 at 21:32
I cant remember as its 6 years since I sold
mine I remember it only has those funny little inserts in the side which are different on each side and dont go right through Other wise a piece of hard wire up from that grommet which is a sort of a 4" x 2" oval one isnt it Pull it out and try to fiddle the wire up till you can see it from the top of the side panel.Or down from the top if you measure it you will have an idea of how far to go.
The best thing to use is the plastic insert that goes between sheets of flooring as its tough and flexible and can be manuevered a bit
Question Why are you putting a cable for a TPMS Most run to the trailer by wireless
Mine did although I had a booster box in the front of the van. You can have it for the postage if your unit runs 433mhz
Here is an alternative if your cable is long enough There is an irregular triangular shaped stamped part in the firewall in front of the driver.
Check inside there is nothing behind it and you can drill a hole in it, put a grommet in and run the cable through it and down to the right hand chassis rail. You will find a wiring loom running along the top of it.. Cable tie your cable to that and out the back. I did that with my heavy power cables for the van.
604651
Reply By: David T6 - Monday, Oct 03, 2016 at 19:15
I have a 100 series and installed the rial for the Inawise 203 in the rear cargo area. As we have draws, I just let the magnat attach to the rear draw frame at the rear
seat member, no problem with signal transmission.
Removing the trim as above, pull out from top and drop cable in as required.
604867
Reply By: Trevor - Tuesday, Oct 04, 2016 at 16:21
Thanks to all who responded.
As I said in my original post one of the problems is the draw/cargo barrier system.
I worked out how to get the trim off (yes it just pops off using a paint scrapper) but then it fouled on the cargo barrier.
I investigated how to get the wire outside under the body or though the chassis rails. That became too difficult so I have just threaded it back under trim and above the carpet and then about halfway along and under the rear carpet trim. .
I had to make up an extension using some small co-ax cable and some SMA connectors
The TPMS now seems to pick up the signal from the trailer wheels more consistently but the proof will be when we do a longer trip.
Trevor
604884
