Friday, Oct 21, 2016 at 19:59
Such passion.
Lets put a few things in perspective.
All forms of power conversion have losses, the
inverters, the plugpack power supplies and other devices.
Yes in
inverters there are standing losses ( that happen with the thing just running) and conversion losses( that vary with the load drawn).
Putting specific figures on these losses is unreliable ..... they can vary from manufacturer to manufacturer and from unit to unit. ... and how they are expressed.
We can not say that a 300VA inverter will have less losses than a 600VA inverter without some specific information about the specific
inverters.
It may be that one specific 300VA inverter may have more losses than a specific 600VA inverter.
Unfortunatly the sellers don't always publish standby currents and conversion losses, then there are issues of accuracy.
I have modest reasonably modern
inverters in catalogues that list standby currents in the 200 to 300mA and conversion efficiencies in the 85 to 90%.
Yes then you have the standing losses and the conversion losses in the 240V power supplies for these units you want to charge ...... the losses there are harder to track down ...... remember too some of these power supplies are over sized for what they are charging so their losses may be higher than necessary.
It is reasonable to expect efficiencies somewhere between 70% for an analogue power supply and up as high as 90% for a switchmode.
so running a plug pack off an inverter you could easily be looking at combined conversion efficiency as low as 60% pluss standing losses.
Then we look at the very small amounts of power used to charge many of these devices.
If we are looking at non standard high current USB, we are talking about 2.1 Amps at 5 Volts ..... total of 10VA. MAXimum, lower current USB may be as low as 500ma at 5 volts 2.5 VA.
Some of the devices we are charging off USB will be drawing less than the standby current of the inverter.
So this is most definitely something to consider.
Pretty much If you have devices that charge from USB...... the best potion is a 12 volt USB charger, either plug in or permanently mounted.
That is anything up to a tablet or a full sized camera.
When we get to laptops things change, most laptops charge off a higher voltage ..... even my little 10 inch charges off 19 volts.
But as mentioned there are specific DC supplies or universal laptop chargers ..... and yes they work.
They are in them selves DC to DC
inverters and can be expected to be about 85 to 90% efficient.
NOW lets talk about cost ...... apples for apples from the same catalogue.... retail prices.
a 360VA pure sinewave invereter is $339
A 150 watt universal laptop power supply is $75.
In this day and age, there is very little reason to introduce 240V into our vehicles.
605268
