positioning redarc solenoid in gu
Submitted: Wednesday, Jun 02, 2004 at 12:44
ThreadID: 13388 Views:2081 Replies:7 FollowUps:0
2nd tray & batt is in,solenoid in hand looking for a 'flat' area to fit the bugger.
a)does it have to be near main batt?
b)will it mind getting showered with mud occasionally?(it will be siliconed)
Reply By: madcow - Wednesday, Jun 02, 2004 at 13:46
3.0 OR 4.2TD? 4.2 Has cruise std now and I relocated it down 30mm which left a flat area on the firewall for installation. No! it would not have to be near the battery but accessibility would need to be considered.
AnswerID: 61340
Reply By: Bonz (Vic) - Wednesday, Jun 02, 2004 at 15:11
fitted mine near the second batteryfar RHS theres a panel there and already has holes in it to fit the redarc.
AnswerID: 61348
Reply By: Brian - Wednesday, Jun 02, 2004 at 16:42
The Instructions say to mount it as close as practical, to the main start battery!
I mounted mine between the start battery and fire wall, made an adaptor bracket out of flatbar and used existing holes! let me know if you want some photos?
Brian
01 4.2TD ST Wagon
AnswerID: 61358
Reply By: howie - Wednesday, Jun 02, 2004 at 17:18
sorry guys, forgot to say the gu is a 4.5 petrol.
will look at suggestions when i get back to the beast tonight. thanks howie
AnswerID: 61363
Reply By: Member -Bob & Lex (Sydney) - Wednesday, Jun 02, 2004 at 17:19
Mine is on the inner guard between fuse box & fire wall
AnswerID: 61364
Reply By: rolande- Wednesday, Jun 02, 2004 at 23:50
I went to the trouble of fabricating a bracket for the isolator to bolt into some captive nuts already in the R/Hand guard, between fusebox and firewall. Ready to fit all up then found that isolator will bolt straight into two of the captive nuts, one 6mm and the other 8mm I think. Two hours fabrication, threw away the bracket and installed in 5 minutes, and as close to original battery as it would get, wish someone had posted this earlier.
Rolande
AnswerID: 61458
Reply By: flappan - Thursday, Jun 03, 2004 at 16:17
Mines a 4.5 Petrol Patrol , and my Redarc is as close as I can get it to the battery. In fact , a matter on inches.
From memory , its bolted to the Suspension tower , just behind the battery , using a bolt that was there , with just a nut screwed down.
If you want a piccy , let me know.
AnswerID: 61514
