Blind as a bat....
Submitted: Friday, Jun 04, 2004 at 11:16
Leroy
Hi all,
I usually try to do a search b4 I post but recently I searched and was coming up with nothing but then today I noticed the 'switch post view' has to be set before articles in the archive will come up when you search...what a goose! Hope this helps others.
Leroy (reading with my eyes closed)
Reply By: ExplorOz Team - David - Friday, Jun 04, 2004 at 17:25
Leroy,
I wondered how many people picked that up. Thanks for posting this (I knew about it) and it happened when I added the Topic and Full Details check boxes. It is not that easy at the moment as you need to set the Active/Archive/Both either before or after you run the search. I would like to be able to set these options once. With this in mind I have been thinking of changing the Text links for the Active/Archive/Both and the Post sort options into the same little check boxes this way you will be able to specify what you want and hit Go.
I just need to find the time to get it done - soon I hope.
61713
