shovel holder
Submitted: Sunday, Jun 06, 2004 at 17:57
oddy
Hi all
Any advice on a shovel holder device for a TD5 '03 disco. Is there an aftermkt fitting that uses the spare on the back without going to Kaymar etc.
I have a rola rails with cage rack so if anybody has fitted one that way pls advise.
Thks
Reply By: The Banjo - Sunday, Jun 06, 2004 at 19:16
Just a thought.....my current method......IF you don't use a wheel cover, AND you have threaded holes in the wheel centre for hub cap bolts, you might try running a skinny bolt straight through the shovel handle and doing the bold up into one of those hub cap holes......that's my current method. The handle is cushioned by the rubber tyre, the threded holes are already there.....you just need a longer than average bolt with a wing welded on the end for hand turning.Rola HD racks ( not the LD ski type) have a shovel accessory that bolts on.
61963
Follow Up By: oddy - Sunday, Jun 06, 2004 at 23:09
Thks Banjo.
Prob solved!
3 cheers for exploreoz.
323396
Reply By: Peter McGuckian - Sunday, Jun 06, 2004 at 19:59
Have a look at the holder amde by Rhino rack - can be olted onto other racks. Also the rubber holder - big fist is the name, I think from ARB outlets (made in US - $19.95 - simple and easy to fit).
61972
