Water crossings.
Submitted: Tuesday, Jun 08, 2004 at 19:29
James M
Is there any pitfalls to tieing the radiator fan still during a
water crossing?
What are the reasons for tarping up other than
water getting into the air intake?
Reply By: Member - Jack - Tuesday, Jun 08, 2004 at 20:00
The idea of the tarp is to create a dam effect, producing a bow wave which in fact pushes the
water in front of you, and not have it slurping up around your engine. Naturally, this means you don't stop as you move through the
water (if you can help it ...).
Have not heard of tying up the radiator fan before, but I am aware of instances where the fan has been sucked into the radiator during
water crossings. If I was worried I'd probably disconnect the fan belt, but others may have more imaginative solutions to that one.
I have been lucky .. done a few
water crossings, but always as a last option and I will drive
miles (kms) to find a more shallow way through. Seems easier to drive than to repair.
Safe travels
Jack
62330
Follow Up By: James M - Tuesday, Jun 08, 2004 at 20:11
Thanks Jack for your ideas.
James.
323653
Reply By: Member - Brian (Gold Coast) - Tuesday, Jun 08, 2004 at 21:27
Being a novice myself... I learnt all I could before "practicing"....
Always try to find the shallowest route.
Always walk the crossing first...... obviously only if it ain't croc/alligator/piranha infested.
Keep a constant speed and keep the "bow wave" happening
Never, repeat NEVER change gears while your running gear is submerged.
Don't try to go too fast, you run the risk of the radiator fan "propelling" forward into the radiator!
Hope this all helps!!
62354
Reply By: Crackles - Tuesday, Jun 08, 2004 at 21:38
Tieing up the fan could lead to damage of the viscous coupling & on the majority of cars is totally unneccesary. On a diesel fitted with a
snorkel,
water splashing around the engine bay makes no difference. The chance of a viscous fan going through a radiator on a
river crossing is remote (never seen 1) and easily resolved by fitting a tarp.
Tarping up is particulary usefull on petrol cars to stop
water splashing over the spark plugs & distributer or to stop excess mud through the altinator etc in deep bog holes. Cheers Craig...............
62355
Follow Up By: Member - Pesty (SA) - Wednesday, Jun 09, 2004 at 12:54
Tarp up as fan being sucked forward into radiator is not that remote.
323718
Follow Up By: Kev - (Cairns,QLD) - Wednesday, Jun 09, 2004 at 21:57
Apparently the 100 series fan is very close to the radiator, it does happen !
323818
Follow Up By: Crackles - Thursday, Jun 10, 2004 at 17:58
As it happens Kev I own a 100 series. Now I'm not saying it couldn't happen but the fan is 60mm off the radiator & as the blades are only 120mm long they would need to bend almost a right angles to touch & I tried to bend them but they don't even go close.
Pesty you make it seem as though it is a common occurance by your comment .I would be keen to hear from anyone that has actually done it and not just hearsay. In 22 years of driving including hundreds of deep river crossings at work & with clubs, I've never seen or heard first hand of a single fan hitting the radiator hence why I said it was remote.
If the fan is too close on some cars by all means tarp up as a precaution on deep crossings, but from what I've seen fans into radiators are often more myth than fact.
Craig
HZJ105
323977
Follow Up By: Kev - (Cairns,QLD) - Thursday, Jun 10, 2004 at 18:11
Iv never looked at the 100 series fan but im sure i read on another
forum that a bloke damaged his 100 series radiator on a crossing, i remember it because i went & measured my 80 series. (60mm)
As you said, i haven't actually seen it.
323980
Reply By: tour boy - Wednesday, Jun 09, 2004 at 08:28
You never have to worry about the fan unless it is a fixed blade type ie no viscous coupling. The viscous unit stops with the weight of the
water hitting it where the fixed one acts as a propellor and usually goes through the rad.
62383
Reply By: Rod - Wednesday, Jun 09, 2004 at 09:34
I have a fixed fan on my LR 110
I usually undo the tensioner bolt on the alternator so the fan belt can slip if it has to before crossing deep
water. Have had it over the bonnet no worries with this technique. Never bothered with a blind
62388
Reply By: Member - Rohan K - Wednesday, Jun 09, 2004 at 09:45
James, tarping up is your best option, for the reasons mentioned above. Do that (and it's simple) and you won't have to worry about the fan.
A few more tips:
Take a break before doing a
water crossing, if have the time. It will give the brakes and diffs time to cool down a little and possible avoid warping disks and sucking a bunch of
water into the diffs.
Most
water crossing are bests tackled in second-low and at a walking pace. That maintains a nice, steady bow wave and gives you the best chance of climbing out the exit if it's a bit tricky.
And, as the others have said, look for the shallowest, firmest crossing, whilst keeping in mind the TreadLightly principle.
62390
Follow Up By: Member - Jeff M (WA) - Wednesday, Jun 09, 2004 at 15:49
I beleive the theory is based on the air already under the bonnet pressurising and keeping the
water from comming up so quickly from underneath, don't know how effective this is in practice though.
I would imagine that the
water surrouning the viscous coupling would cool it and prevent it from locking up. The only thing that might be an issue is it will probally be locked up when you start your car up. Run the motor with the air-con off in neutral at about 1500rpms for about 30 seconds before you go into the
water to let the fan unlock before you hit the
water, once in the
water it should not lock again IMHO.
323729
Reply By: Member - Bob - Wednesday, Jun 09, 2004 at 10:59
I can see that tarping will prevent
water coming straight through the radiator into the engine bay at the speed the vehicle is travelling, but I can't see that it will have any effect on the
water that enters the engine bay from underneath the vehicle during a long deep crossing. So it won't prevent the slow immersion of the engine bay contents (including the fan). To get a picture of what I mean have a look behind the vehicle as you drive through
water slowly - there isn't a nice deep track where the vehicle has bow-waved the
water aside because it fills in instantly. Same with the tarp. If you could see inside the engine bay you would see the
water filling from behind where thge tarp stops.
As for the viscous fan slipping when it hits the
water, it doesn't. If the engine is hot the fan is engaged and the
water won't make it slip.
Cooling fans propellering are problems seen on 100 series LCs and TD5 discoveries (now remedied by new fans with blades that won't flex forward).
62398
Reply By: Kev - (Cairns,QLD) - Wednesday, Jun 09, 2004 at 22:01
I don't know about you guys but 99% of
water crossings iv done have a rocky bottom & its hard to keep up a bow wave as you travel too slow.
With that in mind i wouldn't just rely on the tarp method, use it as an extra precaution.
62516
Reply By: Joe - Wednesday, Jun 09, 2004 at 23:29
I recently crossed a very muddy bog hole with 18" of muddy
water.I was a little sloppy with the way I fitted the blind and got a lot of silt into engine bay.
When I got home I found that I had to hose the radiator core out from both directions under high pressure none stop for 15min, before it flowed through clean.
It certainly highlighted that if I had failed to spend the time hosing it out, the amount of silt in the radiator core would have significantly reduced it's effeciency.
Joe
62550
