Patrol 3L Fault Codes
Submitted: Friday, Jun 11, 2004 at 18:07
Paul
I had the engine light turn on when having problems starting up a few days ago,
after stopping and restarting it turned it self off.
I pull out the Gregorys to retrieve the fault codes,
it reported 0707 - Injector Pump - communication line I cleared it and the car is running fine.
I checked again to verify the fault had cleared and I got 0505
This is not in the gregories, anyone happen to know what this code is?
Paul
Reply By: Bonz (Vic) - Saturday, Jun 12, 2004 at 11:07
Usually the engine light refers to there beign
water in the bottom of the fuel filter, grab the onwers manual and follow the instructions to get it out and you should be ok.
62874
Reply By: sean - Saturday, Jun 12, 2004 at 17:04
My light used to come on quite a bit.
There is a sensor inside the fuel filter and if the filter gets blocked the light can come on, and if you you hit lots of bad corrugations then you might see the light flash on but when this happens it is not a problem
Sean
62901
Reply By: Paul - Monday, Jun 14, 2004 at 17:42
Just drained some....no
water
Error code is actully 0703 (typo) Injector Pump - communication line
I see some fun and games ahead this weekend
Paul
63096
Reply By: Member - Kim (mr) - Saturday, Jul 03, 2004 at 22:09
G'day Paul, I've just been through the very same thing, but my first fault code was
0707 and now after about 6 weeks since that happened and it has'nt come on since
today the light came on agine so i got home and cheeked the code and got the 0505,
so just wondering if you ever found out what the code was?
Thanks Kim...
66338
