01 gu 4.2 dsl aftermarket cruise cont
Submitted: Thursday, Jun 17, 2004 at 12:03
ThreadID: 13854 Views:1776 Replies:4 FollowUps:0
I fitted this cruise control to my 92 GQ 4.2 dsl ute about 2 years ago and it worked very well but now I have just got an 01 GU 4.2 turbo dsl wagon and would like to fit it on the wagon. I was just wondering if any one could tell me an ezy way of connecting the speed sensor wire under the bonnet rather that tracing the wire from the gear box and also which colour wire is the correct one to connect in to
cheers to all for replies in advance
Reply By: JR - Thursday, Jun 17, 2004 at 18:27
I was told in the main harness coming thru the firewall at the drivers side. In this harness is a single grey wire and this is the electric speedo pickup for the original speedo. I hooked in here on my 2000 GU2 3.0tdi and had no problems.
Hook in under the dash if you can, no water in here, you hope, to corrode splice.
I am assuming 2001 wagons had the electronic speedo.
JR
AnswerID: 63624
Reply By: GeroBoof - Thursday, Jun 17, 2004 at 21:59
Thanks JR
I'll check it out sounds about right
Just the sort of info I required
Thanks to all for your help
Gero Boof
AnswerID: 63667
Reply By:- Friday, Jun 18, 2004 at 08:32
you could also ring the cruise control supplier or contact autron electronics in melb they are very helpful people. a very advanced company in this area,
AnswerID: 63703
AnswerID: 63704
