Jackaroo accelerator sticking
Submitted: Thursday, Jun 17, 2004 at 17:38
ThreadID: 13862 Views:4264 Replies:3 FollowUps:4
G'day all,
Some thing that has just happened to my Jackaroo is the accelerator cable sticking whilst I'm driving along.....not really ideal ! What I found was the accelerator cable was not fully retracting back to the closed throttle position. The large external spring responsible for the accelerator returning on the throttle body is loose. One end of the spring is folded, the other is open ended. So where exactly does the open end part of the spring connect to? Any info/diagrams explaining this would be great.......
Thanks,
Mick
Reply By: The Banjo - Thursday, Jun 17, 2004 at 20:46
Every Jack made is not the same MIck ! - any details on year, model, fuel, capacity, etc etc ?
AnswerID: 63654
Follow Up By: mick - Friday, Jun 18, 2004 at 14:08
Doh, my bad !
It is a 10/2000 3.5l V6 Petrol SE LWB...........looks like it could possibly be missing a bush under the spring, but still I'm not too sure what should be there !
mick
FollowupID: 324914
Reply By: Savvas - Friday, Jun 18, 2004 at 15:53
Mick,
I'll take a digital pic of mine tonight or tomorrow (depending when I get out of work) and email it to you if you want.
The throttle body end, right?
What's your email?
AnswerID: 63778
Follow Up By: mick - Friday, Jun 18, 2004 at 17:54
G'day Savvas,
If you can take a photo of the throttle body end that would be great. I'm am faced with a few options at the moment:
1. Hopefully my extended/insurance warranty will cover it,
2. Replace the missing (???) bush from a second hand throttle body, or
3. Replace the whole throttle body.
The third option is what Holden have suggested as the throttle body supposedly isn't broken down in an independant parts breakdown any further than the whole assembly. So they can't supply the missing bush. Hopefully, my first option will cover the third, but just in case, I need to be prepared for option 2 !!
My email address is woofye1@iprimus.com.au
Mick
FollowupID: 324936
Follow Up By: Savvas - Friday, Jun 18, 2004 at 18:55
No problem, Mick.
I'm still at work (yep, on a Friday ... sux big time). I'll do it first thing in the morning.
FollowupID: 324950
Reply By: Member - Bradley- Friday, Jun 18, 2004 at 21:48
shiza mate, you dont need to replace the throttle body just because a bush has gone awol. i will have a look at mine on the weekend and see what the standard set-up is..
AnswerID: 63818
Follow Up By: mick - Saturday, Jun 19, 2004 at 07:47
G'day Bradley,
thats why I'm trying to find out IF there should be a bush or not, but without any sort of service manual I can't be sure. Even the local Holden dealer wasn't too confident about what the problem was. Hence I made a post quizing about applicable service manuals for Jackaroo/Trooper in thread ID 13799.
I definately think it is a major overkill to replace the whole throttle body, but, if I can get it done for free then, u beauty..........
Mick
FollowupID: 325003
