ultimate suspension 2" lift
Submitted: Sunday, Jun 20, 2004 at 18:19
mattie
i am picking up a new gu nissan wagon monday and am looking at putting a 2" lift using ultimate springs and a 42mm foam cell shock also supplied be them. The wagon has a 160lt rear
tank there will also be the following things permanently in the vehicle-dual batt, shower unit, steel bar, 64lt fridge, draw system. It will also have the following when we go away on a trip- roof rack and all the
camp gear to be self sufficient for up to a week at a time.
Has anyone had this
suspension on a similar vehcle and how was it (did it cope with the weight? and how was it with just the every day load in it?)
Reply By: Member - Captain (WA) - Sunday, Jun 20, 2004 at 20:32
Hi Mattie,
Where are you getting a 160 litre rear
tank for a GU Patrol from? Haven't seen anything better than 80 odd litres for the GU rear
tank before.
I would love to get a decent size rear
tank for the bleep y 32 standard rear, but reckon the ~$800 for effectively 2 1/2 jerries is not worth it, but 160 litres - now you are talking.
Captain
64117
Follow Up By: Michael - Sunday, Jun 20, 2004 at 20:40
I think 160 litres
tank would be dragging on the ground!!!!
325245
Follow Up By: Bonz (Vic) - Sunday, Jun 20, 2004 at 21:52
Ummmm 95 litres for the rear
tank is standard on the GU, the 160l job must be a long
ranger
325266
Follow Up By: Member - Captain (WA) - Sunday, Jun 20, 2004 at 22:31
Hi Bonz,
Standard main
tank (under middle row passenger seats) is 95l and rear standard is 32l (for 3.0TD).
Most GU aftermarket tanks, depending on brand, are ~160l replacement main
tank and ~80l replacement sub
tank. Perhaps Mattie meant he was replacing the main
tank, not the rear
tank?
Also Micheal, 80 series rear replacement tanks are ~180l, now thats a mouthful! But you do need new rear springs to cope.
Captain
325283
Follow Up By: mattie - Monday, Jun 21, 2004 at 13:28
Hi Captain
i assumed the rear
tank was the main
tank, the
tank is from 4wd systems(www.4wdsystems.com) they also have a 80lt aux
tank relpacement as
well. I rang a chap locally here in S.A. about
suspension and ultimate is all he recomends unless you insist on another because of the service they give. If the
suspension is not quite right for you he will swap
the springs till it is right they also give a 5year warranty if you purchase both
the springs and shocks together(
the springs are warranty for life). I didn't think it could get much better than that! now you are scaring me.
Thanks for the follow up MATTIE
325332
Follow Up By: Hilly - Tuesday, Jun 22, 2004 at 05:35
K & N engineering in Canning Vale make their own tanks and will show you the product line from start to finish. I'm pretty sure that theirs is around the 160 - 170 litre mark.
No affiliation but they have set up my last 2 vehicles and I've been extremely happy with their advice and service.
325433
Reply By: Wayne (NSW) - Sunday, Jun 20, 2004 at 20:54
Mattie,
If you are getting
the springs from Ultimate
Suspension at Minto NSW, just be carefull. Find out who makes there springs, they could be imported from Inda.
The springs have a bad habbit of saging even under a light load. Also check if a shock should happen to let go in
Alice Springs for example who is there agent there who can replace the shock on
the spot.
I have had a little bit to do with them a few years ago and was not impressed with there product or after sales service.
Go for one of the big players with
suspension ARB or TJM they both have nation wide back up.
Wayne
64120
Reply By: Member - Peter (York) - Monday, Jun 21, 2004 at 16:00
Hi I lifted my Gu coil cab 50mm with King coils and Koni shocks , it works great I will be getting poli air bags fitted for the extra weight once my long range
tank goes in , hope this helps
64218
