Troopy Heater
Submitted: Tuesday, Jul 02, 2002 at 00:00
ThreadID: 1398 Views:1942 Replies:3 FollowUps:0
My brother has just bought a 87 troopy with the 3F motor. Although the engine temp seems to be fine the heater leaves a lot to be desired in these winter months. The previous owner says it has always been like this. Is it common in these models. Thanks
Reply By: LARRY - Saturday, Jul 13, 2002 at 00:00
Bruce toyota heaters normally work very well is the engine temp normal . Is the thermostat working ok. you should feel heat from the heater within 2 minutes . is the heater tap fully opening.if all the above is ok ,maybe the heater core is blocked . hope this may help
AnswerID: 4831
Reply By: Bruce D - Sunday, Jul 14, 2002 at 00:00
Thanks Larry. I am leaning towards a blocked core as everything else seems fine.
AnswerID: 4844
Reply By: Paul - Sunday, Jul 14, 2002 at 00:00
Bruce ,is this vehicle on lpg ? If so check the lpg convertor hoses, sometimes they are connected into the heater hoses and the water takes the least resistance route usualy the lpg convertor so the heater will not heat up. You may have to redo the hoses to the lpg convertor.
AnswerID: 4847
