GU 4.2tdi or 3L
Submitted: Monday, Jun 21, 2004 at 23:49
crayman
Im about to buy a new patrol to replace my old 4.2tb GQ 250ks hard
mine life no probs, undeceided between 4.2tdi or 3l with detronic i know the relibility of the 4.2 and the 3l claim to have sorted out motor probs but i would like to see how they are after 300,000 k`s of hard work (4.2s in mining situations regularly do 400,000 kss with no engine probs) anyone know of a high milage 3 serries
Maurie
Reply By: Voxson (Adelaide) - Tuesday, Jun 22, 2004 at 07:25
you answered your own question. ..prevention is better than cure....
64321
Follow Up By: Michael - Tuesday, Jun 22, 2004 at 08:15
I dont understand his question!!!!!!
325441
325442
Reply By: Member - Chris M (QLD) - Tuesday, Jun 22, 2004 at 09:00
Crayman,
From this
forum, it appears that the series III motor in the 3L TDI has been sorted for any probs.
I also have a 4.2TD GQ and I must admit that I don't drive it like it's
mine, but it just takes it. The donks proven, a little aged and primitive, but that's what I like, you can still work on the friggin' thing without getting into too much trouble. The running gears the same,
suspension is tried and true and the trucks on got EGR fuel now, everything else remains mechanical. I have just ordered a TDI DX 4.2 wagon.
The 3L is quicker, but the motor remains to have been tested like the 4.2 since 1988. My motto was stick with what you know. Get some other opinions and take it from there...
Cheers mate,
Chris.
64336
Reply By: Davoe - Tuesday, Jun 22, 2004 at 09:51
how long do you intend to have it? if you want to run it into the ground over the next 10-20 years go the 4.2 if you want to keep it 3-5 years the 3.0 should be ok even if they have fixed the 3.0 you might get 4-500k out of it but with a 4.2 you know you should. btw no
mine vehicle I have seen gets 400k because the bodys are
well and truly gone before that
64349
Reply By: Member - Gerk Yorke Pen (SA) - Tuesday, Jun 22, 2004 at 10:17
I have the 3 litre series111 with dtronics I'am rappppped with it. Member Roachie (4.2TD Patrol) was back to 4th on the way back from
Berri towing similar weight but he had a roof rack
Mine was quite happy in 5th but who knows what total kms they will do. Cheers from Paul
64354
Follow Up By: Member - Roachie- Tuesday, Jun 22, 2004 at 12:14
Gerk is quite right. I was reading something yesterday about the difference a D-Tronic can make to the amount of torque a lecky-controlled donk can produce. My 2000 model produces 330nm, the standard 3Lt produces 354nm. The newer 4.2 TDi has a figure of 360nm. The D-Tronic is supposed to produce around 400+ nm....No wonder Gerk was cruising in 5th into a strong head wind while I was struggling in 4th.
I must admit, I am envious of being able to plug in a large power increase. I've done a few things to
mine to help it achieve better figures (like a 3" free-flow exhaust and full injector service etc etc). The only other ways I can increase power on this donk would be to add an intercooler and maybe a bigger turbo....but then reliability could be a problem.
As I said, I'm starting to warm to the possible idea of electronic-controlled donks......ON THE PROVISO THEY ARE BULLET PROOF..... I'd also like to see the 3 litre type, but with 2 extra pots on it (4.5 litre)....and a cast iron guarantee that Nissan have definitely solved the blown motor sysdrome. Whack a D-Tronic on that little sucker and you'd have about 550nm of torque and I'd be a happy camper!!!!
325459
Follow Up By: Member - Chris M (QLD) - Tuesday, Jun 22, 2004 at 13:14
Gerk,
Can you tell me what size lift you have in your rocket ship and whether the castor correction bushes were necessary for your lift?
Chris.
325466
Follow Up By: Member - Captain (WA) - Tuesday, Jun 22, 2004 at 13:43
Hi Roachie
Just managed to get back on my
seat - you are warming to the fully electronic fangled dangled diesels??? Don't tell me the dinasour has come of age ;-)
While I think the series 3 GU 3.0TD is the ducks nuts, I fully respect the proven reliability of the 4.2 over a number of years. Unfortunately I reckon its only a matter of time before the old 4.2 becomes the new 4.5TD (3.0TD with 2 more cylinders). And even with my one eyed view on these new motors, I cannot but wonder will the "4.5TD" obtain the legendary reliability of the old 4.2.
Cheers mate
Captain
PS. I'm still smiling after beating the 4.5P 80 series. Who would have thought a 4 cylinder 3 litre diesel would ever take the mighty 80 series 6 cylinder 4.5 litre petrol. Just think what a 4.5 diesel could do.
325474
Follow Up By: Puddin (Sydney) - Tuesday, Jun 22, 2004 at 13:51
Chris, from memory Gerk has a 50mm lift & the caster kit is for wheel alingment as original have no adjustment
325476
Follow Up By: Member - Roachie- Tuesday, Jun 22, 2004 at 14:23
Captain,
That's what I mean....if the 3 litre jobbie can blow away the 4.5 petrol, I can only try to imagine what a 6 cylinder/4.5litre one with the same technology would be able to do........But it'd have to have PROVEN reliability for me to swap over....PLUS it'd have to still have solid beam axles and not be a Pajero look-alike!! Too much bloody plastic already!!! LOL
Cheers mate.
325480
Reply By: crayman - Tuesday, Jun 22, 2004 at 11:29
Davoe
I agree with yourcomment re body work clapped out befor 400k thats true on the underground vechicles which are clapped out befor 100k, but surface operated vechicles achieve high mileages, driven 24hrs different drivers long trips to different sites (talking about eastern goldfields area)
Maurie
64364
Follow Up By: Davoe - Tuesday, Jun 22, 2004 at 12:14
I have worked in many open pits around the goldfields and I can garantee that the vehicles I have driven are very 2nd hand at only 100k and totally stuffed before 200k If the vehicle is used for transport to sites that may enable it to rack up more ks but the bottom line is that on small sites there are little to no car washing facilitys and vehicles are either left with mud crated from hypersaline
water clinging underneath them 24/7 ( a vehicle we took in for service was weighed before and after they cleaned it and it had 60kg mud atached) or they are washed directly with hypersaline
water. I stand byn my comment that a vehicle used daily in an open pit will usualy be totally stuffed
well before 400k.
325458
Reply By: Truckster (Vic) - Tuesday, Jun 22, 2004 at 13:39
You answered it yourself...
TD42 no question.
Search archives, this has been done about 20020020202292929u2098347298347923874 times before...
64398
Follow Up By: Member - Chris M (QLD) - Tuesday, Jun 22, 2004 at 14:32
Truckster, you counted wrong, it's 20020020202292929u2098347298347923880 times before!
Still good to get an opinion from those who continue to rely on the 3L donk as it becomes more aged!
325481
Reply By: crayman - Tuesday, Jun 22, 2004 at 21:20
Daveo
You are spot on with your coments on pit vechicles ,service and support type vchicles opperate in better conditions and longer daily milages Hyteck, assay labs,Mining contractors ect. Will be interesting see how Brynecuts 15 3L Nissan`s hold up Maurie
64508
