diy suspension install GU Patrol
Submitted: Wednesday, Jun 23, 2004 at 14:11
Peter Sirellis
Hey all,
Just bought new shocks (tough dog) and springs (2" lift) for the GU i got a great deal from Duncans 4wd in oakleigh Melb for $950 inc Tough dog return to center steering dampner, and i wanted to do the install myself i am a little mechaniclly minded but just wondered if any1 had any tips or a step by step procedure used, just wanted to get to know the car a bit better incase i need to work on it out in the scrub, Many thanx Pete
Im just a squirell trying to get a nut
Reply By: Member - Chris M (QLD) - Wednesday, Jun 23, 2004 at 14:42
Peter,
You obviously didn't need the adjustable panhard rods and drop down plates/eliptical bushes???
If not, the process is relatively simple. You'll need at least 2 stands rated to take the weight of the vehicle and a trolley jack. If you are lucky and have a big shed, we found 2 jacks better. What we found best was to drop off the sway bar connects, the trailing arms and shocks, brake lines etc. We put the trolley jack under the diff and jacked one end of the axle up until the spring dropped out. We then put the other lifted spring in and reversed the process. Same with the back. Best to leave at least 2 trailing arms on at any given time.
My best advice: Don't rush it and leave at least 4-6 hours for the job. With a GU the nuts should be relatively easy to ease off.
Have fun mate!
Chris.
64644
Follow Up By: Peter Sirellis - Wednesday, Jun 23, 2004 at 20:44
Thanks Chris, sounds easy enough will give it a go, cheers
325727
Reply By: Martyn (WA) - Wednesday, Jun 23, 2004 at 21:21
Peter,
You'll be right, make sure you have enough clearance to drop the axels, take the
wheels off, bit of drilling if you do the stableliser extensions, let both sides go at the same time it's easier you don't have to deal with the flex in the bar. Let the front brake block go on the front axle otherwise you tend to stretch the flexible line, you may even break it. When you drop the rear axle make sur you have enogh clearance on the near side around where the exhaust is, should be OK, I've changed
mine exhaust to a 3 inch system it gets a bit close when fully articulated. Hope some of this helps.
64739
Follow Up By: Peter Sirellis - Thursday, Jun 24, 2004 at 20:29
Thanx mate it helps me heaps
325945
Reply By: srowlandson - Wednesday, Jun 23, 2004 at 21:33
jack up the rear end enough to get the
wheels of the ground (both)
put axle stands under the chassis.
remove both
wheels.
undo the bottom shock mounts,
under both sway bars.
lower the diff down far enough to dilodge
the springs (brake lines are long enough if only doing a 2" lift.
remove the top shock mount and replace(this is a pain!)
re fit in opposite way.
front i do the same method...
Did my brothers about a month ago in about 2 hours (front and rear)
steve
64743
Follow Up By: Member - AndrewPatrol - Thursday, Jun 24, 2004 at 19:24
Steve why do you replace the shock the other way?
325925
Reply By: Truckster (Vic) - Wednesday, Jun 23, 2004 at 23:57
yup easy as pie to do, just think, and take your time.
64773
Reply By: srowlandson - Thursday, Jun 24, 2004 at 10:21
where abouts are you?
If your in the western side fo the city and the time is right i might be able to pop over and give you a hand
64810
Follow Up By: Peter Sirellis - Thursday, Jun 24, 2004 at 16:47
Ok Thanx im in the westn subs Avondale Heights you can call me on 0411 609 508 ill be doing it Friday morning
325871
Follow Up By: srowlandson - Thursday, Jun 24, 2004 at 17:15
bugger.
I am east keilor but i am working tomorrow.
sure you don't want to do it tonight ;)
325883
Follow Up By: Peter Sirellis - Thursday, Jun 24, 2004 at 19:28
start work at 4:00pm mon-fri
325927
Reply By: Member - AndrewPatrol - Thursday, Jun 24, 2004 at 19:22
One more small butcher tip-----lock some vise-grips on to the bottom of your front shocks so you can undo
the nut. lock 'em where the shock is welded to the spindle thingo so you dont obstruct the
bore inside the tube. not sure of the proper way.
64923
Follow Up By: Peter Sirellis - Thursday, Jun 24, 2004 at 19:29
Thanx for that will do
325928
Follow Up By: Peter Sirellis - Friday, Jun 25, 2004 at 19:35
Thanks all for the advice everthing went
well, took just over 4hrs, the car looks and handles great, once again thankyou
326069
