rear lights pajero
Submitted: Wednesday, Jun 23, 2004 at 17:48
ThreadID: 14061 Views:2718 Replies:3 FollowUps:3
im going to hook up the rear light, whats the best way to do it ;ie:where is the best place to pick up the wires from?????
thank you all for your kind help
Reply By: Member - Pesty (SA) - Wednesday, Jun 23, 2004 at 17:52
Have you checked to see if they are laying inside the back panel, just a thought.
AnswerID: 64679
Follow Up By: REX.....(Adelaide) - Wednesday, Jun 23, 2004 at 17:59
bottom ones are there, top not that will change wen i start im going to turn revesing light section to indicator top and bottom to tail and stop .
there is a section where the reversing lights should go in.
FollowupID: 325680
Reply By: Rokkitt - Wednesday, Jun 23, 2004 at 23:04
Just fitted the rear light on my Paj, currently wiring it up. As I have to remove panels I will be running cables for future expansion but here's how I will be running the light.
1. Run new cables to cig lighters from distribution point behind rear seats - connected to aux battery and constantly live.
2. Fit a relay with the high current fed from the the distribution point. Switching the relay from two switches in serial, one in the rear cargo area and a switch on the front console (Illuminated).
I think this covers all the legal issues as well, as long as the rear light is adjustable. I decided not to switch it with my reverse lights as generally the standard lights are adequate, when I am offroad I an simply leave the rear switch in the on position for control in the cabin.
These are my ideas anyway, if I have got anything wrong now is a good time to correct me, no panels refitted yet.
Rod
AnswerID: 64763
Reply By: Rosscoe - Thursday, Jun 24, 2004 at 09:40
If it's an NP I can give you step by step instructions.
AnswerID: 64808
Follow Up By: Frosty-SA - Thursday, Jun 24, 2004 at 17:16
Rosscoe, I would like your step by step instructions very much. Have just ordered an NP and connecting the lights is one of my first jobs.
FollowupID: 325884
Follow Up By: Rosscoe - Monday, Jun 28, 2004 at 08:46
Frosty,
Send me an e-mail and I'll write something out for you.
ross.payne@issystems.com.au
Rosscoe
FollowupID: 326403
