4psi rule
Submitted: Saturday, Jun 26, 2004 at 09:52
Member - Eric K (NSW)
Can anyone tell me what the 4 psi rule is for tyres if you have say a difference 7psi from cold to hot does that mean that your original psi was to low or to high.
Reply By: Mad Dog (Victoria) - Saturday, Jun 26, 2004 at 10:07
4psi just right
More than 4psi then under inflated
Less than 4psi then over inflated
65195
Reply By: Hedonist - Saturday, Jun 26, 2004 at 12:47
To add to the succint explanation above:
The change in pressure is an indication of the amount of heat generated by the tyre as the carcass flexes under load.
If a tyre is underinflated the flexing of the sidewall will be excessive and the tyre will generate a lot of heat which will cause a larger increase in pressure that would occur if it was correctly inflated to start with.
Conversly, if the tyre is overinflated, there will be very little flexing of the tyre carcass and a correspondingly smaller increase in the inflation pressure...
Pete
65210
Reply By: Topend - Saturday, Jun 26, 2004 at 12:47
Tyre pressure should be checked when cold, although sometimes this is not possible. Try your high and low pressures when cold then go for a decent drive. Then recheck them and see what they read when hot. Remember your hot pressures for those times when you have to alter the them while hot.
As for the 4psi rule, I sometimes vary my pressure by more than this depending on weight etc.
Topend
65211
Reply By: Member - Meggs - Saturday, Jun 26, 2004 at 20:24
I read somewhere a while back that it was 4 psi for car tyres and 6 psi for 4 x 4 tyres. Does anyone know what is right?
65251
Follow Up By: Member - Brett H (QLD) - Monday, Jun 28, 2004 at 17:59
Bridgestone told me 10 years ago that 4 psi was good for 10R 15's
326480
Reply By: DaveNJude - Monday, Jun 28, 2004 at 15:01
Eric
Check out this link to the NRMA
http://www.mynrma.com.au/travel/do/cc4/cara3.shtml
Dave n Jude
65515
Follow Up By: Rosscoe - Monday, Jun 28, 2004 at 15:33
Hi DaveNJude,
Read the articlle.
Now, how do you define a "Large 4WD Tyre". I run 265/70/R16 on my 4WD and 265/75/LT16 on my dirt road caravan. 4 psi or 6 psi test?????
Rosscoe
326456
Follow Up By: DaveNJude - Tuesday, Jun 29, 2004 at 12:37
Rosscoe
My guess is the article is aimed more at car style tyres so I would imagine the heavier sidewalls etc on Light Truck etc tyres would have to generate more heat - so 6psi would be the go :)
326574
Follow Up By: Member - Glen O (NSW) - Thursday, Jul 08, 2004 at 07:04
6 psi
[ View Image]
327674
