Defender Snorkel
Submitted: Tuesday, Jun 29, 2004 at 19:52
Member - David
My Mate has a 1994 Defender TD tabletop and is going to fit a
snorkel. On investigation, where the air intake comes to the motor from the front RHS fender there is a "Drop Out" section (T piece) in the piping.. We assume this is to let
water out if the kids stick the garden hose in the air inlet through the fender. Now what happens if you fit a
snorkel? Do they provide a different fitting to replace this? Obviously the
snorkel would be a waste of time as any submersion above the "Drop Out" would allow
water to be sucked into the motor.
Would appreciate some info about this, and suggest if there are any Defender owners not aware of this that they stay out of
water more than 400mm deep (or less)
David
Reply By: Rosco - Bris. - Tuesday, Jun 29, 2004 at 21:06
Davo
There're been a few posts on this issue recently. I think you'll find that any correctly fitted snorkels will address this issue by only allowing air in the top.
65713
