Bigger Exhaust
Submitted: Thursday, Jul 08, 2004 at 09:29
Matt (W.A.)
Hi All
I Want to Upgrade / Replace my current Exhaust from the Cat (Catalytic Converter) back and was wondering how big was big enough? I did the same to my old Duv Duv Ford Laser (Lowered to the bump Stops and Ear Drum splitting Stereo) and that was 2¼’ Dia the Place that installed it said that if I went any bigger I wouldn’t have enough Back Pressure and that I would start to burn exhaust valves out. My first question is, can I go bigger than 2¼‘ on my Pajero as it has a bigger Engine 3.5l as apposed to 1.6l in my ford. And secondly will I see any increased Performance /improvement if I do?
Thanks in Advance
Reply By: Member - Chris M (QLD) - Thursday, Jul 08, 2004 at 09:42
Matt,
In all of my 4wd vehciles thus far (toyota, nissan, suzuki) I have upgraded all of the exhausts. I must admit that although I didn't feel a huge difference in the Tojo and suzi, (pretty standard) my nissan definitely felt the difference. If you check my specs, you'll see why.
I had a 2.5 fitted straight through when the turbo was fitted but later was told by my current performance dude that 3 inch was much better, and what a change.
For your style of vehicle, you may find a little more power but you will most likely notice the cleaner rev range of the vehicle, breathing much easier IMHO.
Cheers mate,
Chris.
66919
Follow Up By: Matt (W.A.) - Thursday, Jul 08, 2004 at 09:57
Cheers Chris,
Thanks for the Quick reply
327691
Follow Up By: Member - Chris M (QLD) - Thursday, Jul 08, 2004 at 10:03
What size lift in the Paj?
327693
Follow Up By: Matt (W.A.) - Thursday, Jul 08, 2004 at 10:20
At the moment Cooper Discoverer A/T Shoes 265’s, Enforcer H/D Springs
Will eventually put Rancho RS9000 Adjustable Shocks In and Cooper Discoverer A/T Shoes 285’s its lifted about 2’ at the moment
327694
Follow Up By: Member - Chris M (QLD) - Thursday, Jul 08, 2004 at 10:24
Looks good mate!
Cheers.
327695
Reply By: Truckster (Vic) - Thursday, Jul 08, 2004 at 10:36
Increased performance will be 'it sounds different' so will feel better.
I went for extractors and 2.5in exhaust on
mine before the turbo, and it made 0 difference. Others will defend their purchase by stating massive increases in power, cause they dont like to admit it was waste of coin.
If your not replacing the complete system, I cant see how there would be difference in power, as its still restricted from the engine to the cat..
Is there a Pajero club in WA? Maybe a call to them may assist.
http://www.pajeroclub.com.au/
maybe of use to you they are in Vic, but a few emails from you to them may get you some genuine answers.
Also have a look at
http://www.pps.net.au/dinos4x4/ hes in WA with a modded Paj..
YMMV
66923
Reply By: Member - Roachie SA- Thursday, Jul 08, 2004 at 11:05
Matt,
I've got a 3" on my TD Patrol. In order to have any affect, like Truckster said, it needs to be all the way through the exhaust system. In my case, that included a whole new dump pipe (from Binskins at
Wauchope NSW). The dump pipe alone cost $220- and provides a much bigger appeture (spelling?) right at the turbo outlet, for the gases to escape into the 3" pipe work. Also, I only used a short Lukey hotdog muffler and no resonator at the rear end. It made a noticeable difference to the truck's low-down performance (ie from idle to when the turbo cuts in at around 1800rpm). Noise level has hardly been affected, but it does have a different note to a standard 4.2 T/d
66931
Reply By: Matt (W.A.) - Thursday, Jul 08, 2004 at 14:52
Thanks Gents,
will look into getting extractors, Sports Cat and a 3' from there back. this is in preperation for the Supercharger.
66959
