Can't see in the dark!
Submitted: Friday, Jul 09, 2004 at 10:06
Member - John C (QLD)
Just upgraded springs on the disco, had a problem not getting quite what I wanted due to something re the abs preventing my preferred spring being installed (so the fitter said).
Sitting a bit higher in the back than the front, took it for a drive last night and couldn't see past my nose, obviously the headlight angle being affected downwards. There are also polyairs in the back. The fitter said it may settle down and correct, I am doubtful, he will fix if it doesn't. Will polyairs soften? Don't think he meant
the springs.
Can anyone advise of their own experience?
JOhn C
Reply By: Kiwi Ray - Friday, Jul 09, 2004 at 10:12
Hi John
You should be able to adjust the lights up. Simple job to do either a screw driver or small socket.
Drive truck up to a wall, lights on full mark centre of beam on wall back away 10 feet, then bring beams up to that mark
hope this is of some help.
Ray
67093
Follow Up By: Member - John C (QLD) - Friday, Jul 09, 2004 at 10:25
Of course.
unless LR has made that a
shop job too...
327835
Reply By: Disco200Tdi - Friday, Jul 09, 2004 at 10:12
Put some weight in the back for a couple of weeks and
the springs will gradually settle down a bit. With the polyairs you only need about 3 psi when the car is empty, just enough to stop then pinching b/w the spring coils.
John D
67094
Follow Up By: Member - John C (QLD) - Friday, Jul 09, 2004 at 10:26
will do
ta
327836
Reply By: Foss - Friday, Jul 09, 2004 at 18:04
Did you get the lift done at TJM @ Coopers plains ?
67142
Follow Up By: Member - John C (QLD) - Friday, Jul 09, 2004 at 18:22
Is that you KH?
327901
