Subaru Forrester 2001
Submitted: Monday, Jul 12, 2004 at 10:10
ozie
We are complete novices and are planning a trip through Qld and up to
Darwin but we were wondering the capabilities of the Forrester, off road, as it is an all Wheel Drive not 4wd drive and don't really know if what sort of roads we could take it on.
We will be towing an Avan but thought we could do trips of a day on tracks with the Subaru
Reply By: sdc - Monday, Jul 12, 2004 at 11:27
I have a Forrester and you will find you are able to go most
places with no difficulty remembering ground clearance and wheel travel are the limitations. I would suggest fitting an Aluminium sump guard as the only necessary modification but you may like to also consider a switch to isolate the radiator fan for
water crossings.
Really your major limitation in your lack of experience. Let caution be your guide (but be a little adventurous) and you will have a grest holiday.
67420
Reply By: DaveNJude - Monday, Jul 12, 2004 at 14:37
Ozie
I second that about the sumpguard, I smashed the plastic one the first time I hit some serious ruts so now I have an alloy one from SubaXtreme which seems fine. The other thing I plan on getting is manual winch just in case. I know they are not easy to use but as insurance they are worth it. Lack of clearance is the price you pay with a "softroader" but otherwise they are great
Happy travels
DaveNJude
http://home.iprimus.com.au/daveju/Caravan/Caravan.htm
67449
Reply By: Member Colin - NSW Bungendore - Monday, Jul 12, 2004 at 18:28
The Forester will cope with conditions harder than you would probably ever dream of tackling!.
The Subaru Club in your state could offer you good advice.
As mentioned, a sump guard is important - it is a pity that Subaru don't fit them anymore, or even offer them as an option. A steel guard is preferable, they bend and don't crack like the cast aluminium one recomended above. A guard off any older model Subaru can be easily modified to fit.
Tyres are another weak point on ALL 4WD's - change from the standard H/T to A/T - your car has 15"
wheels and there is a lot of choice in A/T tyres available.
If your car has self leveling
suspension, be careful not to overload the rear
suspension, the SLS is prone to fail if heavilly 'stressed' - SubaExtreme make
suspension options for most Subaru models.
Good luck
67493
Reply By: ozie - Monday, Jul 12, 2004 at 18:35
Thankyou for your replies. We now feel confident we can do a few extra tracks along the way.
67497
