Cast iron - dutch oven??
Submitted: Monday, Jul 12, 2004 at 18:31
Chubbs-jnr
Hi all,
Can anyone please tell me what difference if any there is between a cast iron pot and a dutch oven??
Also what is the best way to prepare the oven after it has being bought i have heard that you need to burn off and oil before you use it ?? is this true??
Chubbs
Reply By: Member - Rick (S.A.) - Monday, Jul 12, 2004 at 19:15
The difference, effectively, is none.
A
camp oven is a cast iron affair, with or without legs. Slow cooking is the order of the day with a
camp oven. Yummmy
as far as running it in..........
oil the oven -just el cheapo cooking oil is OK- & bring the oven to a high heat - on stove or BBQ or the real McCoy in coals. It will smoke a treat. Leave it here for half an hour or so, but make sure it dose not get too hot & go black immediately.
Then, when it has cooled down, wipe it dry with papaer towel.
NEVER wash your
camp oven with soap/detergent. The mix of flavours from the last meal adds to todays meal. Just boil/stew/soak
water in it if it is crusty/lumpy/revolting inside.
67506
Reply By: Member - Sparkie (QLD) - Monday, Jul 12, 2004 at 20:32
Isn't a Dutch Oven something you do with your mates in a car when you have had a dodgy vindaloo the night before?
Sorry I couldn't help myself ;-P
Sparkie(IE not Y) ;-)
67525
Reply By: Voxson (Adelaide) - Tuesday, Jul 13, 2004 at 07:47
I thought a Dutch Oven was when you drop your guts under the bed sheets and then pull the covers up over your misses head and hold her there??... *innocent look*....
67551
Follow Up By: Member - Sparkie (QLD) - Tuesday, Jul 13, 2004 at 08:42
You better be carefull. She may return the favour.
328247
