Solar Panels
Submitted: Monday, Jul 12, 2004 at 19:54
Member - Brian B (QLD)
Hi Everyone,
I will be setting up a deep cycle battery in my new camper trailer and would like to have it set to charge via
Solar Power when we are away from other methods of charging.
Can anyone offer me information on what gear I need to buy and how it should be set up etc as I am a bit short on information on this one.
Reply By: Magnus - Monday, Jul 12, 2004 at 21:06
Hi Brian,
While there is plenty in the archives on this subject, you will need to know the following for a start
Average daily draw in Amp Hours
Then obviously your budget. Solar panels start at $260 plus for 20 watt which is really the bottom end of the requirements. A lot of forumites will agree with this and suggest lot bigger units.
Then you can size the deep cycle battery.
You should take a peek at the following site for info on deep cycle baateries and how they should be handled. I strongly recommend you take the trouble to print it out for further study. It is long but
well worth it.
http://www.uuhome.de/william.darden/carfaq.htm
Hope this is enough to start.
I use 70 amp hour deep cycle (delkor) and a 20 watt solar panel and have been using this set up or similar for a number of years. But I only run lights and radio/cd player. Fridge is gas.
Magnus
67529
Reply By: Member - Wim (Bris) - Tuesday, Jul 13, 2004 at 07:21
Brian.
As Magnus points out lost to consider. If you live in Bris I would be happy to help.
Have a good day.
67549
