HJ60 Wiper Arm
Submitted: Monday, Jul 19, 2004 at 18:07
bbuzz
My HJ60 keeps throwing its internal wiper arm off the wiper motor. The plastic locking ring has worn and to get a genuine replacement I have to buy the whole arm at $300!! True!
Has someone a fix or modification to this problem? The local dealer has seen three this week so it is a
well known problem for them.
Secondhand ones are as worn as
mine. Thanks for your interest.
Reply By: mcgra - Monday, Jul 19, 2004 at 19:40
hi bbuzz
try this site they have come thru for me many times and at a fraction of the price.
http://ec.lunds4wd.com.au/trial/findPart.do
enter the details on year make and model then select group or key word and see what you get.
also call them they sometimes have it but not on the listings
hope this helps
gra
68489
Follow Up By: bbuzz - Tuesday, Jul 20, 2004 at 22:07
Thanks.
You are right. They have a part listed but their email and links are not working. Have to send them a fax.
Bill
329251
Reply By: dellycat - Tuesday, Jul 20, 2004 at 17:14
Hi bbuzz,
We have a HJ60 and had the same problem. You can buy the arm, from the wiper motor to the main assembly, seperately from Toyota and the cost is between $25 - $35. Hope this helps
Dellycat
68679
Follow Up By: bbuzz - Tuesday, Jul 20, 2004 at 22:11
Thanks.
My dealer wants $300! Did you deal with Toyota direct?
Have you an address I can contact for a similar price?
I'll get the hang of these
Forum replies soon!!!
Bill
329253
Reply By: bbuzz - Tuesday, Jul 20, 2004 at 21:35
Thanks for your answer. That is what I thought it was worth too but the local dealer wants $300.
Did you deal with a dealer or did you contact Toyota direct?
68729
Reply By: dellycat - Wednesday, Jul 21, 2004 at 00:58
Hi Bill,
Dealt with Prosser ( I hope I don't get into trouble for using their name) Toyota in Gosnells WA. The part in question is the single arm that runs from the wiper motor to the main assembly and joins it behind the middle inspection plate. Will try and help further if required.
Dellycat.
68752
Follow Up By: bbuzz - Wednesday, Jul 21, 2004 at 14:33
Thanks. I have emailed Toyota about the price.I wouldn't mind a contact number/email for Prosser if that is OK. The freight will still have me
miles in front with a new part!!
329315
Follow Up By: dellycat - Wednesday, Jul 21, 2004 at 15:23
Hi Bill,
I have just contacted Prossers and they explained that to replace that part in an early model HJ60 you need to buy the whole assembly for $300, but the arm in question can be replaced with an arm from a later model that can be bought seperately from the main assembly. He said other people have done this and it seems to work. (Our part was ordered by our mechanic so we didn't know this was the story before now). He quoted us $27.30 and the part number is 8516490A00 and said you should be able to get this part through your local Toyota Dealer. If you have further problems, the phone number for the Parts dept at Prossers is (08) 9492 1355.
By the way, where are you?
Hope this information helps you out.
Good Luck
Dellycat
329319
Reply By: bbuzz - Wednesday, Jul 21, 2004 at 18:10
Thanks. I am totally blown away with this
Forum. You guys out there are so helpful and knowledgable! I will investigate your hints and let you know if my area has the same response! I would like to think they do not know about it. Anything else and I am being had big time!
I am in NSW @ Gosford area.
Really appreciate your contact.
68844
Follow Up By: dellycat - Monday, Jul 26, 2004 at 21:58
Just enquiring.........
Did you manage to obtain the part or are they still trying to sell you the whole thing????????
Dellycat
330013
Reply By: dellycat - Wednesday, Jul 21, 2004 at 18:48
Pleased to be able to assist! and I hope that you are able to get and fit the part without further trouble. We all have to look out for each other.
Dellycat.
68854
Follow Up By: bbuzz - Tuesday, Jul 27, 2004 at 20:46
Thanks. I have the part. The 'saleman' I first talked to was not around so no problems. I may make an enquiry to the dealer management as to whether they were going to charge me the $300 if I had left the vehicle with them; but fitted the cheap part and pocketed the difference.
What a cynical person I am!!
330171
Follow Up By: dellycat - Wednesday, Jul 28, 2004 at 00:45
Probably would have charged you the $300 + GST!!!!!!!! now you have got me doing it (cynical that is). Glad to hear you got the part and all is
well as you have been quiet over the past couple of days.
Dellycat
(will get the hang of answering in this
forum one day!!!)
330209
Reply By: dellycat - Wednesday, Jul 28, 2004 at 00:40
Dellycat
69992
