The Fattest
Submitted: Monday, Jul 19, 2004 at 21:18
ThreadID: 14814 Views:2119 Replies:3 FollowUps:0
What's the largest Volume Tyre I can fit on a 13" Rim and also on a 14" rim,- if I can fit it under the Camper. The standard 13" Tyre nearly completely flattens out over a reasonable bump. Trying me hardest to turn an on road camper into something that will handle a bit of rough stuff..
Reply By: Member - Jiarna (SA) - Monday, Jul 19, 2004 at 22:52
Hi Jeffrus
I'd say you need higher load rating rather than bigger volume. To get that, go for LT (light truck) tyres. Can't find any 13" LT, but there are hundreds of 14". Best bet might be to go for 14" rims and the tallest 14" LT tyres you can fit. I use Toyos on my trailer with no problems since I went to LT construction tyres.
AnswerID: 68535
Reply By: Member - Jiarna (SA) - Monday, Jul 19, 2004 at 23:00
If you want to get into the rough stuff with a camper trailer built for on-road use, make sure the drawbar and chassis can cope with it. My trailer needed extensive modifications before it could cope with off-road use. I found this out the hard way when the A-frame broke off at 80 km/h on the Oodnadatta Track and the fully loaded trailer did cartwheels up the road. Pretty spectacular, but somewhat upsetting at the time!!
AnswerID: 68538
Reply By: rolande- Wednesday, Jul 21, 2004 at 22:59
Jeffrus,
What is the stud pattern? If Commodore or Falcon you can get 15" steel rims and then fit 215R15 off road tyres. I did this and gained 2" clearance at the axle. Does not make it an off-road camper but useful for that last 200m into secluded camp spots.
Rolande
AnswerID: 68939
