Plastic water tanks for four wheel drives
Submitted: Tuesday, Jul 27, 2004 at 12:06
Austravel
Does anyone have some contact details of companies that supply the poly tanks thata can be fitted under four wheel drives. Specifially I'm after one to fit under a GU patrol ute and one to fit just in front of the rear mud guard. I've seen the latter on a couple of cruisers but don't know were to source them.
Reply By: Member - Steve M (SA) - Tuesday, Jul 27, 2004 at 12:24
Hi Austravel
I have seen some fitted to 100 series Cruisers when the spare tyre used to be. They sourced the
water tanks from caravan suppliers.
69860
Follow Up By: GeorgeFoessel - Wednesday, Aug 18, 2004 at 09:37
Hi, The
water tanks I have fitted to our Landcruiser utility are made by Gough Plastics in
Townsville. They are specifically designed for mounting under the tray of a utility, with special bracketing, brass attachments and metal fittings. The tanks are of a very high quality and have an 80 litre capacity. We have 2 fitted to our 4x4 Catering vehicle and they fit neatly between the rails of any tray. They are easy to fit and come complete with breathers and filler pipes. They are also designed that they can be back filled for faster more efficient filling.
They aren't cheap, but quality never is. They are available through Motorama 4x4xMore Salisburu
Brisbane Ph.3717 2700
George
www.motorschool.com.au
333250
Reply By: Truckster (Vic) - Tuesday, Jul 27, 2004 at 12:43
Check a thread out on outerlimits4x4.com in the members section by ROLY.
He has one for his GU Ute, he picked up last week. phtos and company info there too.
69863
Reply By: Gordon - Tuesday, Jul 27, 2004 at 13:09
Try Gough Plastics
www.gough.com.au
69868
Reply By: mid life - Tuesday, Jul 27, 2004 at 13:25
I got through ARB southside (
Brisbane) that holds 80lts and fits under a LC 79 series, had to fit myself because it wasn't one of their usual product line
69874
Reply By: waveslave - Tuesday, Jul 27, 2004 at 14:16
Hiya, ]
I have a 52l stainless steel
tank fitted under my 78 series LC. It works a treat, and is super tough. It also has a pump hooked up to the battery.
69878
Reply By: Member - Bradley- Tuesday, Jul 27, 2004 at 15:01
TJM have right and left hand poly tanks in a triangle shape i am pretty sure.
69884
Reply By: dingdong - Tuesday, Jul 27, 2004 at 16:31
Hi austravel ,
I had 2 made up by Vortex plastics in
Geraldton out of 300 mm. diam polt pipe they did a fantastic job & they will make them to any shape you require .
Cheers dingdong ,
69901
