Safari Snorkel GQ Patrol - Water trap
Submitted: Monday, Aug 02, 2004 at 13:19
KO2004
Hi All,
We recently had a safari
snorkel fitted to our GQ patrol but we can't see a
water trap anywhere. The mechanic told us that the bit where the air intake is is also the
water trap and is self releasing. We are inclined to disbelieve him as we have seen other safari snorkels on the same model with
water traps.
Do you think the mechanic is right?
Reply By: luigi - Monday, Aug 02, 2004 at 13:42
By
water trap, do you mean were the air filter is? If so my GQ has s small pocket at the back on the inside if you like, but if the
water did get in it will just sit in there as there is no way for the
water to get out.
But it does have what they call a
water separation system build into the head of the air intake itself. Have a look at their website and you'll see what I mean (
http://www.safari4x4.com.au/docs/snorkel/air_ram.htm ).
I though the same thing when I first bought the car. I have since been through those car washes that just use a jet of
water, and no
water got through.
Hope this helps you and gives you peace of mind.
70881
Reply By: Truckster (Vic) - Monday, Aug 02, 2004 at 14:13
Call Safari and ask them.
But your spanner man sounds correct.. Depending on model of
snorkel and car... (EG which motor)
70889
Reply By: KO2004 - Monday, Aug 02, 2004 at 14:39
It's a 4.2litre petrol engine on the 1990 Ti model
70896
Reply By: Martyn (WA) - Monday, Aug 02, 2004 at 14:42
K02004,
There is a
water trap on the bottom of the primary air filter cannister, it is self releasing. The self releasing bit is a rubber ball with a split in on one side,
mine was perished and cracked so I replaced it when I installed my snorkle, my choice, I would rather have it than not. I found it when fitting my Safari snorkle, I'm sure that part of the fitting procedure for the snorkle is to remove this
water trap for
water proofing. If it's any help my GQ was a 1992 4.2 TD ST, if the mod was year dependant.
70898
