GQ and QU patrol wheels
Submitted: Friday, Jul 19, 2002 at 00:00
John Rooke
Can i fit the 15"
wheels with 31-10r15 tyres from my GQ onto a GU series 11 Patrol which has 16"
wheels
Reply By: larry - Saturday, Jul 20, 2002 at 00:00
I believe that the GQ has 6 studs & the GU has 5 studs so,the
wheels cannot be used. about the tyres I would enquire at a good tyre retailer.
Hope this helps.
Larry.
4986
Hope this helps.
Larry.
4987
Hope this helps.
Larry.
4988
Reply By: Derek - Sunday, Jul 21, 2002 at 00:00
John. I can't say that GQ rims will fit a GU, but a guy in my club has fitted after-market 15" rims and 33" tyres to his GU. He did this because he wanted a taller tyre than was able to be fitted to the 16" rim. The car now looks mean but his acceleration and braking have suffered. You will have to check the stud pattern and quantity, the offset and whether the rim will strike the brake caliper. At the end of the project, it's the overall diameter of the tyre/rim combination that matters. Hope this helps.
Derek
4994
Reply By: troy - Monday, Jul 22, 2002 at 00:00
John,
Maybe I have an unsual GU, but me and a mate swap
wheels all the time, he has a GQ, I have a GU. No problems.
I run 16's as standard, he runs 15's. Same stud pattern. You only need to ensure you get the right offset on the rims to ensure the tyres are inboard of the flares.
31's ??? mate go 35's.
Some clarification on a previous post also - 33's on a 15 are exactly the same as a 285/75/16. Simple metric imperial conversion will tell you that. No need to go down to 15's to get bigger tyres on. 315/75/16 - now your talking !
Good luck with the GU John ! - you will love it !
Troy..
5026
Reply By: Guy - Monday, Jul 22, 2002 at 00:00
The GU and the GQ have 6 studs. Not only it can be interchanged between these two cars but it can be interchanged with ALL six studs
wheels. Because 6 studs
wheels are an International Standard. I am talking here about standard
wheels which meet the International Standard and not
wheels which do not respect the International standard.
I have swapped the GU
wheels with RODEO etc..
5030
Follow Up By: Yonnee - Sunday, Jul 28, 2002 at 00:00
Not entirely correct. Although the stud patterns are the same, not all six stud
wheels are interchangeable due to the different
offset used by different manufacturers.
2221
Reply By: larry - Tuesday, Jul 23, 2002 at 00:00
john its time for me to eat humble pie. TROY & GUY are right theGQ & GU do have the same stud pattern. I was getting the 80's &100 series toyota stud patterns mixed up with the nissans.
larry.
5070
