gq maverick brake setup after suspension lift
Submitted: Tuesday, Aug 03, 2004 at 20:06
ThreadID: 15267 Views:2489 Replies:5 FollowUps:1
After l lifting my wagon some time ago by about 2.5 inches have noticed
extra brake dust around rear rims.
On closer inspection, and testing on a wet road(when safe to do so not at great speed) rear wheels locked up very easily. Come to the conclusion brake proportioning valve not working correctly.
Has anybody come across the same problem and any advice on fixing it.
Possibly using a bracket to bring back the relationship between valve and spring piviot point
Thanks to all gq mav
Reply By: stephenjNQ - Tuesday, Aug 03, 2004 at 20:25
hi gqmav,
i think there is a adjustment bolt on the brake valve . just not a 100% sure which way to adjust it. mine was lifted 2 inches and i jusy adjusted that to make the brakes work better.gregery's manual tells you how.(cant find mine still packed up). hope this helps.
regards stephenjNQ.
AnswerID: 71138
Reply By: mr diamond - Tuesday, Aug 03, 2004 at 20:34
in theory the brake proportiong valve will give more rear brake when theres a load so lifting the rear will back of the valve.
another mystery.
AnswerID: 71139
Reply By: Truckster (Vic) - Tuesday, Aug 03, 2004 at 22:42
When we did the 6in lift on my GQ, we raised the bracket on the brake proportiong valve the same amount.
Apparently its a 'rule' you should follow. Although Ive seen and fitted a few 3in kits and never bothered, and never had a complaint.
AnswerID: 71158
Reply By: Member - Stillthinkinaboutit - Wednesday, Aug 04, 2004 at 19:32
As Mr. Diamond said.
Lifting the suspension should actually cause less breaking at the rear wheels.
Sounds like something else is causing the problem, maybe the handbrake is partially on, due to extra strain on cable due to lift ?
AnswerID: 71308
Follow Up By: Member - Stillthinkinaboutit - Wednesday, Aug 04, 2004 at 19:38
mmm,
After reading again, I see it is a GQ you have, then it most likely has tail shaft brake so lift would not affect the hand brake.
FollowupID: 331509
Reply By: gqmav - Thursday, Aug 05, 2004 at 19:12
Thanks to all who inputed some advice.
I actually found that on closer inspection of the load sensing valve and bracket,
there is actually enough adjustment in one of the mounting holes in the bracket which I have adjusted to get the correct braking proportioning front to rear.
My only concern now is for others who have had any lift done, and might find
braking fine until they need to do a panic stop and find that there back locks
up prematurely.
gq mav
AnswerID: 71424
