Bloomfield Track/Lakefield NP
Submitted: Monday, Aug 09, 2004 at 20:54
ThreadID: 15435 Views:2774 Replies:6 FollowUps:2
Me and my boyfriend are planning to travel from Cairns to Cooktown via the coastal Cape Tribulation Bloomfield track. then we are heading inland to drive up through Lakefield NP to Musgrave and then back down to Laura and then to Atherton. We are planning to do this in mid to late October, and I wanted to ask if anyone has done it or believes it is possible to do this trek in a 2wd. Is it strickly 4wd terrian? We did the Oonadatta track last year in a 2wd. Is the Bloomfield Track similar to the Oonadatta? Any advice which be much appreciated!
Reply By: Leroy - Monday, Aug 09, 2004 at 21:05
What kind of 2wd? Something with a bit of ground clearance?
AnswerID: 71937
Follow Up By: Toria - Monday, Aug 09, 2004 at 21:12
Well to be honest I would leave the car choosing to my boy'f - but if a 2wd with ground clearance is more likely to do the track then - yes. We used a Mitsubishi Magna along the oodnadatta track - is that a type of car known for high clearance? What would you recommend?
FollowupID: 332108
Reply By: Member - Nick (TAS) - Monday, Aug 09, 2004 at 21:10
Toria,did the Bloomfield track and Lakefield NP last year and I for one wouldnt like to take a 2wd on either.There are some real steep sections on the Bloomfield Track and if there was 1mm of rain you wouldnt make it.If you go from Cooktown into Lakefield NP on the Battle Camp track hold onto your teeth.It was really rough last year,some of the worst corrigations we had and really suited for 4WD's only.If it was dry the whole time and you took it really slow you may make it but i'd advise against it. I'd buy a 4WD and GET OUT THERE. Cheers Nick
AnswerID: 71940
Follow Up By: Toria - Monday, Aug 09, 2004 at 21:46
Thanks Nick - from what you say a 4wd sounds like a must. So on that note, if we were to buy a 2nd-hand 4wd, ( just something that would do the job, nothing fancy) what price do you reckon we would be looking at?
FollowupID: 332120
Reply By: Moz - Monday, Aug 09, 2004 at 21:17
Hi Toria,
The section between Cape Tribulation and the Bloomfield River has some
extremely steep hills.
We were 2-up in a diesel troopy with minimal camping gear and it was
strictly low-range for some of the hills.
I would think anything less than a 6 cylinder Commodre/Falcon would
struggle and then it would have to have the clearance to ford the river.
And then if it rains it would become extremely dicey.
Don't want to put you off it is a fantastic drive your planning but be
careful with your choice of vehicle.
Moz
AnswerID: 71942
Reply By: duncs - Monday, Aug 09, 2004 at 21:53
Toria,
I'd go with what has just been said. Some of the creek crossings are quite rocky, read large round river rocks. It would be very easy to get stuck on some of these with a 2wd even a realtively high clearance one. Maybe a dual-cab ute with a good limited slip diff would be OK. If it rained you could be in trouble.
It is beautiful up there. If you are serious about seeing that ype of country, and it seems you are, hten trade the Magna on a reasonable GQ for mid teen dollars and go to it. You'll see more places, be more comfortable and safer.
Duncs.
AnswerID: 71957
Reply By: Member - Cocka - Monday, Aug 09, 2004 at 22:41
Hi Toria (short for Vic??)
Don't place yorself in a position of risk, your asking the right q's here but there is a lot of experience required for some trips and having a properly set up vehicle is only half the equation. You can do it cheaply in a 4x4 with minimal camping gear, but don't forget to ask about the "what if's" ie. "what if" this breaks or "what if" we get stuck in a creek etc etc. I'm not trying to put you off, but it's a reallity check.
Could I suggest you find out where your nearest 4x4 Club is, have a talk with them about minimal gear and go along with them on a weekend trip to learn how to use the safety gear, tyres radios etc , properly.
Then you will have a really great and safe trip.
Good luck and safe travelling.
PS - don't buy a lemon - if you look around and make offers, there a some good buys.
AnswerID: 71959
Reply By: Member - Peter K (NSW) - Monday, Aug 09, 2004 at 22:43
Toria
Agree the comments previous, two other suggestions are:
1. Rent a 4wd from cairns and do trip. I have just done Cape and companion had hired a cruiser from http://www.4wdhire.com.au/ . It was a good set up, about $170 a day, but that included everything including roof top tent. It is less if you take your own gear.
2. dont do Bloomfield, Go up Cape Trib, then over to main roads to see laura ect. Although battlecamp was graded in July, bits are still rougth, I have a split exhaust to prove that.
Hope it helps
AnswerID: 71960
