Landrover
Submitted: Wednesday, Aug 11, 2004 at 09:39
ThreadID: 15470 Views:2411 Replies:6 FollowUps:6
Can someone advise a Landrover mechanic/specialist involved in the 4wd scene in Brisbane north. Trying to sort out suspension/tyre issues and other things.
ARB, TJM, Opp Lock are not much help.
Can't blame them when it comes to something sophisticated like a Landrover.
JC
Reply By: Member - Lindsay S (Int) - Wednesday, Aug 11, 2004 at 10:34
www.britishoffroad.com
Forest Glen too far north for you?
AnswerID: 72131
Follow Up By: Member - John C (QLD) - Wednesday, Aug 11, 2004 at 12:47
thks
about an hour drive.
may have to do.
FollowupID: 332348
Follow Up By: Brian - Wednesday, Aug 11, 2004 at 13:59
Will be worth the Drive!!!!
Brian
FollowupID: 332352
Reply By: Truckster (Vic) - Wednesday, Aug 11, 2004 at 10:45
What issues are you having?
AnswerID: 72134
Follow Up By: Member - John C (QLD) - Wednesday, Aug 11, 2004 at 12:46
Truckster,
Just trival mainly, bits and pieces, but annoying, time consuming.
e.g
1. disco has TJM springs (about 40mm lift), but original shocks, polyairs on back. sits highish, std tyres, rides seems hard. do I need to do anything with swaybar etc. i.e suspension. think original shocks are maxing out due to lifted springs, buggered if I know. need it all looked at.
2. want a bashplate, protector plate made for fuel filter near rear tyre etc
3. Tow a camper (1000kgs, 125kg drawbar). std towball too short for AT35 hitch, too close to bumper, need longer but landrover shaft 53mm not 50mm (std aftermkt tongues sloppy).
4. plus whatever else comes up
Basically I need experienced all in one operator for advice relating specifically to this vehicle.
JC
FollowupID: 332347
Reply By: banjodog - Wednesday, Aug 11, 2004 at 15:16
You could also try this workshop for some of your needs - http://www.customoffroad.com.au
AnswerID: 72152
Follow Up By: Member - John C (QLD) - Wednesday, Aug 11, 2004 at 22:01
thks banjodog, could be what I'm looking for
FollowupID: 332407
Reply By: Member - Bob - Wednesday, Aug 11, 2004 at 21:35
Try:
http://autos.groups.yahoo.com/group/AussieDiscoveryII/
AnswerID: 72203
Follow Up By: Member - John C (QLD) - Wednesday, Aug 11, 2004 at 22:00
ta Bob
FollowupID: 332406
Reply By: stevesub - Thursday, Aug 12, 2004 at 11:58
Try MR Automotive at Redcliffe. Excellent LR workshop for all makes and models. Don't know about advice for modifying suspension, etc but worth a call. They have a heap of photos on the walls of Landrovers doing crazy things off road - as you do when you have a Land Rover and not a Torrak Tractor.
AnswerID: 72275
Follow Up By: Member - John C (QLD) - Thursday, Aug 12, 2004 at 14:21
thks stevesub
called them, sounds like they will be the right people.
FollowupID: 332514
Reply By: incisor - Friday, Aug 13, 2004 at 18:42
M & R are good!
also for info and support try http://www.aulro.com/
australian landrover owners website.
AnswerID: 72506
