brake siezure front hi lux
Submitted: Saturday, Aug 14, 2004 at 21:26
cluffy
hi
89 hi lux dual cab 4x4 2.8 lt diesel
front drivers side wheel locked up
replaced all caliper seals replaced rotors replaced disc pads bleed system both sides
couple days latter right hand wheel red hot pads worn out rotor distorted through heat same as before has any body heard of this problem or knows how to fix it.
thanks
cluffy
Reply By: locallaw - Saturday, Aug 14, 2004 at 21:37
Gidday,I think you will find your flex brake hose has collapsed inside.What happens is when you put your foot on the brake pressure is built up in the line and when you take your foot off the brake the pressure is not released therefore brakes to that caliper are on all the time.Volvos were noted for this (early models)as they had 2
flex lines one to the caliper and one return.The return hose collapses and no release in pressure.
Hope this helps
Locallaw
72637
Reply By: Yeah Mate - Sunday, Aug 15, 2004 at 03:03
Cuffy,
Just jack the front of the car up, check to see if both
wheels spin free, if not, undo the calliper bleed screw of the effected side to see whether pressure is present and whether the calliper has released. If, when you jack up the car and the
wheels are free to turn, start the engine allow vacuum to build and pump the brakes, Re-check, as I would say locallaw has hit the nail on the head.
72654
Reply By: Utemad - Sunday, Aug 15, 2004 at 12:53
My brother had the same problem on an old Datsun once.
It was the flexible brake hoses.
Utemad
72675
