How do you clean out a/c pulley & clucth?
Submitted: Wednesday, Aug 18, 2004 at 08:34
Savvas
Hi all,
Got the Jackaroo a bit (a lot) muddy on Sunday and managed to get crud into the aircon compressor clutch and pulley? Now it's making a low grinding type noise.
I have tried cleaning out by flushing it with
water and have been able to reduce the amount of noise but haven't been able to get rid of it altogether.
Does anyone have any suggestions on the best way to get the dirt out, without having to remove the compressor from the vehicle?
Reply By: hoyks - Wednesday, Aug 18, 2004 at 08:50
Last time I filled
mine with gunk I just left the motor ldling and pointed the hose at the clutch. Also try turning of the motor and shoving the end of the hose right in the clutch. Lots of
water from a number of directions usually does the trick. A spray of truck wash and then a good wash may also help.
WD40 is not a good idea as the clutch tends to slip a lot. I have seen that done too.
73055
Reply By: Truckster (Vic) - Wednesday, Aug 18, 2004 at 09:35
I would say dont waste anymore time, do what you will end up having to do, and remove it and do it properly.
Isnt doing good grinding away in there, and longer you leave it, the worse it will get.
Just remove it, and clean it up properly.
73063
Follow Up By: GO_OFFROAD - Wednesday, Aug 18, 2004 at 09:48
And perhaps replace the bearing which may be now making that grinding noise....
333254
Follow Up By: Truckster (Vic) - Wednesday, Aug 18, 2004 at 10:28
was thinking that too, while you have it apart - saves doing the job again.
333261
Follow Up By: Savvas - Wednesday, Aug 18, 2004 at 11:00
That's the problem. Harrison (the maker of the compressor) hasn't made dismantling the pulley an easy job on this particular compressor.
I wanted to go down the cleaning out path before I go the disassembly path.
You guys are most likely right, though .... bugger
333267
Follow Up By: Truckster (Vic) - Wednesday, Aug 18, 2004 at 11:38
Can you replace the compressor with something from another model car?
EG Commodore or something that are dime a dozen?
Sanden 508's are about $30 from wreckers!
333279
Follow Up By: Savvas - Wednesday, Aug 18, 2004 at 12:50
Don't know ... shall investigate.
333286
Reply By: Austravel - Wednesday, Aug 18, 2004 at 11:12
When
mine was pretty noisy an AC mechanic had me cycle the air con on and off with the switch and poured thinners over the clutch. Took the noise away completely and that was about 8 years ago so didn't have any long term effects.
73082
Follow Up By: Savvas - Wednesday, Aug 18, 2004 at 12:49
Thanks Austravel,
Interesting idea. Can you tell me what sort of noise it was making?
333285
Reply By: Austravel - Wednesday, Aug 18, 2004 at 13:17
Grinding, from dust and sand.
73092
Reply By: Savvas - Friday, Aug 20, 2004 at 18:30
Mobile a/c tech coming around tomorrow. Nothing else worked.
Bugger ... :-(
73440
