toyota surf
Submitted: Thursday, Jul 25, 2002 at 00:00
ThreadID: 1568 Views:3884 Replies:3 FollowUps:2
hi i drive a 3l turbo charged diesel toyota surf 1994 model. (auto) after towing a small caravan for about 5 to 6 hours , the bottom of my gearstick gets that hot i can barely touch it , can someone tell me if this is normal in in this make of vehicle or not . regards pieter
Reply By: RAY - Thursday, Jul 25, 2002 at 00:00
YES MY SURF DID THE SAME .I FITTED AN OIL COOLER INFRONT OF THE RADIATOR TO COOL THE TRANSMISION OIL NO MORE PROBLEMS.
AnswerID: 5127
Follow Up By: Pieter - Monday, Jul 29, 2002 at 00:00
thanks Ray i took my surf to a transmission repairer and was told that there was not enough room to fit one he then told me that as long as my warning light did not light up not to worry . i have one other problem that you or maybe some one else can help me with it blows a lot of black smoke out the exaust pipe yet it does not use any oil have tried several service stations to no avail thank you again for your reply regards Pieter
FollowupID: 2233
Reply By: RAY - Monday, Jul 29, 2002 at 00:00
There is lots of room to fit a oil cooler.I removed the front grill and fitted a two row cooler very easy, connect with two rubber hoses to the original pipes at the bottom of the radiator.Do not fit the cooler inside the lower bash plate/engine protecter it will get squashed if the plate gets bent.The black smoke is unburnt fuel you need to have the pump and injectors looked at.
AnswerID: 5238
Follow Up By: Buddy - Friday, Aug 16, 2002 at 00:00
Thanks Ray i had 4 new injectors fitted and no more black smoke also a oil cooler will be fitted next service
FollowupID: 2492
Reply By: Gray - Thursday, Aug 15, 2002 at 00:00
Hi, in regards to your black smoke? Could be a couple of things. I was told some time ago that the fuel pump is setup to whether north or south Japan. plus our fuel can be part of the problem. Like oils ain't oils
diesel ain't diesel, the difference for my hzj80 750-900 km's for the main tank thats 20%, normally 830-880 km's through one supplier.
My 80 had a smoking problem, but apparently it was set up correctly
I've added a hyclone and use redline RL2 fuel additive, results, heaps less smoke and a saving of an extra 200km/ 140lt's This includes factoring in the price of the additive. I think the fuel additive is a good place to start and monitor fuel usage.here's to improvment.
AnswerID: 5740
