storing tyres
Submitted: Thursday, Aug 19, 2004 at 14:13
ThreadID: 15681 Views:3044 Replies:6 FollowUps:6
Hi forum Gurus,
What is the best method to store a spare set of tyres on rims.
I was given a set of tyres and rims, so have decided to use these on the road and store my BFG,s for treks etc and refit them when the other tyres wear down
Will
Reply By: Truckster (Vic) - Thursday, Aug 19, 2004 at 14:54
My Simex's sit in the shed out of sunlight, and weather...
Should be fine.
AnswerID: 73256
Follow Up By: Vince NSW - Thursday, Aug 19, 2004 at 15:05
I do the same Truckster.
Do I leave them at road PSI or drop down or inflate higher ?
Vince
FollowupID: 333420
Follow Up By: Truckster (Vic) - Thursday, Aug 19, 2004 at 15:08
I just clean em and throw them in the shed, then check pressures when I put them back on.
FollowupID: 333421
Follow Up By: Vince NSW - Thursday, Aug 19, 2004 at 15:11
Thanks for that. Looks like I am doing the right thing at least one time in my life
FollowupID: 333424
Follow Up By: GO_OFFROAD - Thursday, Aug 19, 2004 at 21:54
Tyres of today store well, keep them out of direct sun, is about it, and dont armor all the sidewalls, as this actually cases the rubber to dry out, and perish.
FollowupID: 333454
Follow Up By: Martyn (WA) - Friday, Aug 20, 2004 at 21:05
T-man,
For what it's worth I assume that all the tyres are stored rim side down and not on the tread of the tyre along sid each other. Correct?
Keep the shiny side up
FollowupID: 333594
Follow Up By: Truckster (Vic) - Saturday, Aug 21, 2004 at 13:29
just one ontop of the other on a sheet of ply....
FollowupID: 333626
Reply By: Member- Peter & Mrs Peter, Lez - Thursday, Aug 19, 2004 at 21:14
Hi Will
I reckon buy another 4wd of your choice and store them on it, easier than changing wheels over when you go away. LOL. Cheers Peter
AnswerID: 73330
Reply By: Will - Friday, Aug 20, 2004 at 12:58
Thanks for the replies.
Having two 4wd,s would be a solution, I hate changing over the tyres.
Out of the sunlight around the back of the house is the way to go.
Will
AnswerID: 73395
Reply By: Glenno - Friday, Aug 20, 2004 at 22:42
Best place to store them is at my place :)
Glenn (looking for a 2nd set of tyres & rims)
AnswerID: 73465
Reply By: Chaba - Friday, Aug 20, 2004 at 22:51
Glenno,
Now you're just being silly.
Will, I'm happy to take care of your tyres.
Please make sure that they're attached to your fourby, and deliver it to my place.
Don't make it too early though. My wife will get the dirts.
Chaba.
AnswerID: 73466
Reply By: rock hoper - Saturday, Aug 21, 2004 at 11:53
you can jus t put them in the shed as they are .
but if you are storing them for long periods i would surgest you drop the tyre presher down to about 20 psi .
AnswerID: 73485
