After market cruise control
Submitted: Thursday, Jul 25, 2002 at 00:00
Joe Bennett
I am interested in fitting a cruise control system to a 1999 Daewoo Musso 4WD. Does anyone have any suggestions on what would be appropriate? Thanks
Reply By: Beddo - Thursday, Jul 25, 2002 at 00:00
I just fitted a commander cruise control unit to my Surf - you can get the stick control (goes either side of steering column) or lever control on the steering wheel (costs more though). The electronic cruise control is better than the magnetic ones that operate off your tail shaft. I'm happy with the stick control as it has a light on it to tell you when it is engaged etc, the levers on the steering wheel do not. Only can recommend ringing round to see what suits - but would go for electronic - though it does depend on what other electronic devices you have on your car. I had a cable run speedo so had to go for cable and a fancy horn set up also meant I had to go for magnets.
5148
